Author Topic: If you are running a Dyna 2000 on a 836 high HP engine  (Read 1690 times)
Offline sparty
  • I just play one on TV
    • Gallery
« on: October 17, 2007, 06:35:50 PM »
How do you know where your timing sweet spot is?  I currently have mine set at 35 degrees.  Could it benefit from going lower or higher on the timing? scondon, Ilbikes, and Mike can you help?  Tuning experts your advice is welcomed.
Sparty
1972 CB750 K2 Cafe' Style
Offline scondon
  • Mmmm......tasty bugs
Re: If you are running a Dyna 2000 on a 836 high HP engine
« Reply #1 on: October 17, 2007, 06:56:12 PM »
 I've only got a month or so more experience than you with the Dyna 2000 so maybe Mike or Gordon will have more input. I did start with 37.5 degrees on #4 setting, bike was very responsive but had lean rattle. I've been jetting down the CR's(110main now), raising the needles, and retarding the ignition timing. Also I've dabbled with the 1-3,5 curves but never stuck with any of them for long.
 As far as what I've noticed from changing the ignition timing alone, I get better mpg and the bike doesn't run as hot the further I retard the ignition. I'm currently at 33+degrees( just left of center between 32.5 & 35 marks) and running 91 octane. I have not noticed any real change in power by retarding the ignition.
 I'm still not fully satisfied with my all around tune, though it has improved greatly from my initial starting point. When I get the carb mix where I really like it I'll get back to trying some different advance points. Most likely will happen on the dyno as I hope to tune by "seat of pants", then fine tune the AFR on the machine and pull a couple runs at different timing degrees to see what measurable difference there might be.
  At the moment, Godspeed still has a hole in the ground where the new dyno is supposed to go. Possibly in by next week ;)
« Reply #2 on: October 17, 2007, 07:02:13 PM »
Mine is at 34 degrees Art
Offline sparty
    • Gallery
« Reply #3 on: October 17, 2007, 07:11:14 PM »
My bike is running a bit hot at 35.  I'll try 34 and see what happens.
« Reply #4 on: October 17, 2007, 07:14:24 PM »
An efficent engine doesn't need a lot of advance Art.
« Reply #5 on: October 17, 2007, 07:16:55 PM »
It will get hot Art, it's a new motor and also don't forget, it is bored out to it's maximum, the cylinder walls are very thin now.
Sam. ;)
Offline Jim F
  • go baby go
« Reply #6 on: October 17, 2007, 07:25:42 PM »
Hell you guys need to get an ARD and forget about it..................:):):):)
who needs all that fancy dancy cherry 3000 stuff
Sounds like your in the ball park Sparty
I seem to remember running my Dyna around 36 degrees and running race gas
but that was a year or so ago
Jim
2002 RC51 1000 (SP2)
1983 GS1100EC Suzuki
1992 KTM500 2 stroke
1975 CB750/836 Honda
1978 GS750/840 Suzuki
