Author Topic: "jumping" speedo  (Read 6430 times)
Offline dpen
"jumping" speedo
« on: October 18, 2007, 04:57:05 AM »
My speedo has been jumping all over the dial for a long time.
I was going to strip it but found a thread (can't find it now) about flushing the speedo with isopropyl alcohol.
IT WORKS - three flushes and I have a rock solid speedo needle.
Offline Triffecpa
Re: "jumping" speedo
« Reply #1 on: October 18, 2007, 09:07:22 AM »
what exactly did you flush?  the cable or the housing?
TR
Offline Klark Kent
« Reply #2 on: October 18, 2007, 09:33:38 AM »
bodi recommended that in september.  describes the 'process.' is that the thread you were looking for?
-KK
-KK
75 CB550k
95 KLR650
www.blindpilotmovie.com
download the shop manual:
you'll feel better.
listen to your spark plugs:
Offline dpen
« Reply #3 on: October 19, 2007, 03:29:43 AM »
Took the speedo off, turned upside down, poured about 15-20 ml (bought a 100ml bottle from a pharmacy) into the cable hole, held my finger over the hole & shook s**t out of the speedo.
Drained fluid & repeated twice more, put speedo back on & presto
« Reply #4 on: October 19, 2007, 04:54:29 PM »
70% ??
« Reply #5 on: October 19, 2007, 05:15:12 PM »
Is there a requirement to replace whatever old lube is washed away?  It seems that just cleaning the old crud out and not re-lubing it is only doing half the job? ;D
Offline dpen
« Reply #6 on: October 20, 2007, 09:59:20 PM »
G'day Tez, I'm not sure if the original post had anything on lubing but it makes sense.
There's a good post on the "salocal" site regarding speedo stripdown & lube so when I get time I'll do that but this fluishing is a definate quick fix for the jumps.
Offline ofreen
« Reply #7 on: October 20, 2007, 10:46:04 PM »
About 15 or 16 years ago, the speedo needle on my 750F started jumping and the speedo occasionally squealed, especially in cold weather.  I had an aerosol can of white lithium grease with a straw handy so I squirted grease into the small gap between the collar and the shaft the cable goes into.  That took care of it immediately and it has been fine all these years since.  I keep expecting to have to do it again sometime, but it is still doing OK.
Greg
'75 CB750F
« Reply #8 on: October 20, 2007, 11:12:08 PM »
Hmmnnn, that might be the go Offy, clean it out with alcohol first, then give it a squirt of white lithium grease, I'll give it a try! Cheers, Terry. ;D
