Thanks RX for the pics. In case you don't know, instead of pasting the link from Photobucket you can actually copy and drag the image code and then paste it into your post. That way the pic will show in your post . . .Don't have an earlier year piston to add to the bunch do you? What year is the head in the first pic? Seems like the pistons with their increased dome height would be a major culprit in the CR bump. Still don't know if there is a head contribution though. KB02, think of it this way, (with everything else being equal) when the a cylinder's valves are closed, the piston's higher dome is now pushing farther up into the combustion chamber compressing the mixture into a smaller place . . . higher compression . . .I would guess this would also lead to slight loss in displacement??
