Author Topic: Where can i get small slip-on's like this  (Read 1321 times)
blantonator
« on: October 22, 2007, 05:05:09 PM »
I'm looking for some small slip-on's like these that will fit my 1.5" head pipes
Any ideas?
thanks,
Offline cben750f0
Re: Where can i get small slip-on's like this
« Reply #1 on: October 22, 2007, 07:44:01 PM »
do you want them for a two stroke?, reason i ask is the bike you are looking at is two stroke..... they are off the expansion chambers for this bike..... not sure if you can get them for the four stroke bikes?....
anyone???? ???
peace
Offline rhinoracer
« Reply #2 on: October 22, 2007, 07:54:37 PM »
Like cben said, they are for two stroke motors. Don't know the difference so all I can do is speculate.
Two strokes spin double as fast as 4 strokes so they should flow double also, although there exhausts are tuned so the backpressure works with the expansion chamber.
Two stroke exhaust has a higher pitch than 4 strokes so they should be tuned to reduce higher frequencies better than the 4st rumble.
If you install them let us know how they work cause they sure look trick.
Baja native.
blantonator
« Reply #3 on: October 22, 2007, 08:19:38 PM »
it's for a sohc4, and was just using the picture for reference.  Essentially I'm just looking for a small/discrete slip-on like this, but maybe a little more modern
« Reply #4 on: October 22, 2007, 08:41:23 PM »
If you are talking for the bike in your last picture, you can get the correct silenced race megaphones from Swarbrick exhaust in the UK.
Try google.
Sam. ;)
