Author Topic: Tappet/Valve Adjustment after Disassembly/Reassembly - CB500/4  (Read 2190 times)
Offline chopstar500
  • King of the Nighttime World
« on: October 22, 2007, 06:48:37 PM »
I've tried the factory manual and a quick search here, but I'm still confused.
Manual says the "T" 1-4 mark is used to determine cam/crank position, but how do I know that I am on TDC of the compression stroke if I've loosened all of the adjustment screws to prevent damage?  ???
Any help? Thanks!!!
Completed Project "Four Pack" - My 1971 CB500 KO - Now For Sale - email me for more info!
Offline mattcb350f
  • Hardly a
  • 1974 CB350F
Re: Tappet/Valve Adjustment after Disassembly/Reassembly - CB500/4
« Reply #1 on: October 22, 2007, 07:52:24 PM »
Good day chopstar500,
Had a question like your's come up a little while ago,  I Dug up the link
(http://www.sohc4.us/forums/index.php?topic=26981.msg275665;topicseen#msg275665)
That should help you out..
 Matt.
Gallery at:
Offline chopstar500
« Reply #2 on: October 22, 2007, 07:59:59 PM »
 Matt.
Thanks Matt - that should help. Guess I picked a bad day to quit sniffin' model glue.  ;)
Offline rhinoracer
« Reply #3 on: October 22, 2007, 08:05:29 PM »
I think he means with the adjusters loose neither #1 or #4 valves will move so there's no easy way to tell which one is on the compression stroke.
I would thread both #1 and #4 valve adjusters the same number of turns intake and exhaust when at the T 1-4 mark and you will immediately notice which ones can be threaded more than the others.
On the cylinder where both adjusters went farther in evenly that's where you have compression.
On the one where the adjusters are uneven and "less threaded" for a lack of a better term you're on the exhaust-intake stroke.
Hope I didn't make it more complicated.
Baja native.
Offline mattcb350f
  • Hardly a
  • 1974 CB350F
« Reply #4 on: October 22, 2007, 08:16:36 PM »
Good call rhinoracer, I thought I was missing something :D
You'd be all day trying to find a tight tappet with them all loosened off :o
 Matt.
Gallery at:
Offline Klark Kent
« Reply #5 on: October 22, 2007, 10:15:56 PM »
while they all might be loosened the same amount of turns out, you may need to do the feel which one is opening and come back around to TDC, like Oldschool_iscool suggested in that linked thread above.
-KK
-KK
75 CB550k
95 KLR650
www.blindpilotmovie.com
download the shop manual:
you'll feel better.
listen to your spark plugs:
