Author Topic: 1971 cb450 loping over 70  (Read 1916 times)
Offline cadler
« on: October 23, 2007, 03:38:30 PM »
I just redid a 71 cb450 it runs great except when in 5th gear accerating from 70 going up a slight hill ,the thing styarts to lope and will not go faster??? I can live with it but i would like to correct the problem if i could.
I just put in new points and timed it....any suggestions???
Offline tbpmusic
Re: 1971 cb450 loping over 70
« Reply #1 on: October 25, 2007, 08:30:43 AM »
Check your float bowl levels??
bill
Bill Lane
Offline dusterdude
« Reply #2 on: October 25, 2007, 08:46:49 AM »
i think you`re lean.which a low float level will certainly cause.
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline Klark Kent
« Reply #3 on: October 25, 2007, 08:55:20 AM »
valve adjust?
-KK
75 CB550k
95 KLR650
www.blindpilotmovie.com
download the shop manual:
you'll feel better.
listen to your spark plugs:
Offline cadler
« Reply #4 on: October 26, 2007, 04:56:40 AM »
valves adjusted, i think the idle air screw is 1-1/4 turns out ,floats  not sure would they need to be higher or lower?
Offline Klark Kent
« Reply #5 on: October 26, 2007, 07:45:24 AM »
i''d still check the gaps to make sureyou didnt lock nut one too tight...
happened to (because of) me
good luck
-KK
-KK
75 CB550k
95 KLR650
you'll feel better.
