Author Topic: bench sync cargs on 76 cb 750  (Read 3643 times)
shadow37620
« on: October 26, 2007, 10:11:40 PM »
 ive rebuilt the carbs on one of my 750's and at the moment i cant afford a set og guages so i need some info on bench syncing the carbs  i also have a 71 cb 5oo i rescued from a barn a few weeks ago that i'm eventually going to put together for my wife as an aniversary gift before next june  and the tips will come in handy even though they are two different styles of carbs the 500 is more like the carbs on my 78 cb 750  so hopefully the info will work on all models
      thanks
Offline Steve F
Re: bench sync cargs on 76 cb 750
« Reply #1 on: October 26, 2007, 11:40:14 PM »
"bench syncing" the carbs is used to get it close enough to start the bike for further tuning.  Eventually you'll need to buy or borrow a set of gauges to do it right.  Even the slightest adjustments to an already synched set of carbs can change the way it runs.  To answer your question, you'll need something like some pieces of 14 or 12ga solid wire that you will be using to set the gap at the bottom of the slides and get them as uniformally set as possible.  14 or 12 gauge wire should be stripped of insulation before you use it, and you place a piece of it in each carb under the slides and adjust the nut on the top of each carb until they all match, then lock down the jam nut.  Be careful you don't twist anything when you loosen or tighten the nuts.
Offline nteek754
  • 1973 K3/750/836/70 1970 750 chopper 1973 cafe
« Reply #2 on: October 27, 2007, 05:48:34 AM »
Hey all , I like useing a drill bit for my gauge have fun Craig in Maine
seven fifty four ever its not the destination its the journey Ive been collecting these old dinasours for 33 years . they are quite an ICON
Offline KB02
« Reply #3 on: October 27, 2007, 06:44:39 AM »
I used a 1/8th inch drill bit to bench sync my carbs.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
Offline mcpuffett
« Reply #4 on: October 27, 2007, 08:29:32 AM »
Me to  ;), cheers mick.
