Author Topic: First real CB500 problem  (Read 5268 times)
Re: First real CB500 problem
« Reply #25 on: November 14, 2007, 04:10:22 AM »
In that case you are going to have to keep on going down!
Remove cam and head
Remove cylinders and check bores for pickup and small ends for tightness---I seen one in 30 years siezes and never found out why!
Priscbs
« Reply #26 on: November 14, 2007, 06:41:36 PM »
Well, the hell with it then.  I didn't buy that new cylinder hone for nothing ;).  I started pulling things apart today.  I had to stop just before I got to the fun part, trying to break a cylider head free that is 35 years stuck. :-[
Priscbs
« Reply #27 on: November 14, 2007, 08:02:01 PM »
I started ganking on the head and low and behold, the cylinders released before the head did.  Is this going to be a problem?
« Reply #28 on: November 14, 2007, 08:37:59 PM »
Frequently happens and even if it dont look like it the base gasket is usually moved enough to leak, which is why i say pull the cylinders if you remove the head!
You need to split the head off to remove the cam chain cushion,
? did you remove the two 10mm head bolts (1 at front & 1 at rear of camchain tunnel)
Priscbs
« Reply #29 on: November 15, 2007, 07:23:18 AM »
I was using the worthless manual and it only said to 'loosen' the bolt, and it only mentionsed the one at the rear.
