Author Topic: cb750 clutch springs  (Read 1778 times)
Offline 72 yellow
« on: October 30, 2007, 04:48:03 PM »
I have a 1972 CB750 K.  I am in the process of getting it out of the cardboard box it resides in and up on its feet again.  In checking the clutch spring length mine are approx. 1.440 in. in length.  The Honda factory manual I have says 1.257 in is correct free length. Since I have no info on what previous owners have done to this bike, I would like to know are these heavy duty springs, or just the wrong ones ?  I called a couple of local dealers, but no help.  Got started on the clutch due to sticking plates.  Any thoughts ?? ???
USN20
Re: cb750 clutch springs
« Reply #1 on: October 30, 2007, 05:11:01 PM »
72 yellow, See this recent CB750K clutch spring thread:
http://www.sohc4.us/forums/index.php?topic=26844.0
Offline 72 yellow
« Reply #2 on: October 31, 2007, 06:58:28 AM »
After reading the thread, I can assume that these are not the correct ones.  I have 22041-300-000 part number from the Honda fiche as the correct set for the K2 model.  The dealer said this is correct, but they are no longer available. Question is can I use these springs ?  I have seen the Vesrah spring set at CycleX.  ???
« Reply #3 on: October 31, 2007, 09:23:56 AM »
Probably put in there on purpose.. I always run stronger clutch springs, less chance of slipping.
« Reply #4 on: October 31, 2007, 12:10:36 PM »
I agree. Barnett springs with OEM fibers and steels.
Offline 72 yellow
« Reply #5 on: November 18, 2007, 04:03:38 PM »
Thanks for all the info..I still have one question, are the Barnett springs longer or are they the same length as stock and have a heavier spring rate  ??? ???
Offline Kevin D
  • SE Michigan
« Reply #6 on: November 18, 2007, 04:47:25 PM »
My Barnett springs measured 1.440" long, 0.105" wire diameter when they were new. I replaced the springs only and put my glazed friction discs :( back in. I'm no drag racer but the new springs tremendously reduced clutch slipping ;).
71 CB750 K1
104,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
