Author Topic: New from OK  (Read 1530 times)
inkedupirishman
New from OK
« on: October 31, 2007, 07:43:41 AM »
Going to look at a '71 CB500/4 today. It's supposed to be all original, but no carbs.
Any tips/info on checking this thing out? Thanks.
arbormystic
Re: New from OK
« Reply #1 on: October 31, 2007, 07:55:56 AM »
Welcome to the board
Offline mattcb350f
  • Hardly a
  • 1974 CB350F
Re: New from OK
« Reply #2 on: October 31, 2007, 10:21:54 AM »
Might be a bit late if you're looking at it today, but anyway..
High milage generally means more wear...seems obvious, but what that means is that you will likely have to rebuild the engine to make it a good reliable rider. Although, I would do this if its got low mileage, with high mileage, you will end up replaceing more of the expensive internals.
On that note.. make sure the overall wear of the bike matches the what it says on the clock. If it's really tuckered out and it says its only gone 15,000 miles, than those were a rough 15k.
In general, look for things like: engine...is it loose and does it run.
                                         frame....is it straight or modified
                                         Wheels...are they round  :D,, check for loose spokes
                                         Tank....dents and rust, old gas
                                         Electrics..dont want hack jobs with lots of electrical tape
                                         Forks...Pitting.. dont want that either
Also make sure the ownership paper checks out..This should actually be your first concern
Know what you want to spend and have an idea of what you want your bike to be when it's ready to ride. If the bike needs a little work and you plan to go all cafe on it, then a bike that's been neglected might not be a bad base.
If you want one to restore, make sure a lot of the little things are still there that may cost a lot or be hard to find to replace.
That should cover most things...
One thing that I do, and I'm not sure if anyone else does this is check all the switches on the handle bar. If they've been used a lot they will be kind of loose and the paint will be worn off the housings. If there reletively tight, then that's a sign of low milage. Speedo's can be rolled back and most other things can get replaced over time...but hardly anyone replaces those switches when they get loose  ;)
 Matt.
Gallery at:
Offline Badger 5
    • Gallery
Re: New from OK
« Reply #3 on: October 31, 2007, 10:44:55 AM »
Where in OK are you located
76 CB550K
75 CB200T
68 CL160 (AHRMA R78)
07 Triumph Bonneville Black
75 XS650
Offline steven400/4
  • tyre inspector
  • that nice
Re: New from OK
« Reply #4 on: November 04, 2007, 09:19:25 AM »
welcome from the uk  ;D ;D
steve ;)
1978 honda 400/4 f2 my baby
Offline Roach Carver
Re: New from OK
« Reply #5 on: November 11, 2007, 08:00:34 PM »
welcome and ditto
Offline kpier883
  • is quite the
Re: New from OK
« Reply #6 on: November 13, 2007, 05:19:45 PM »
Welcome aboard.
74 CB750
80 CBX
82 KZ1000 K2 (LTD)
57 1/2 ton chevy
Offline bill3749
  • Remember, Some people are alive only because it's illegal to shoot them.
  • Honda 1978 CB750K, 1979 Corvette ZZ4 Crate
Re: New from OK
« Reply #7 on: November 14, 2007, 04:52:46 AM »
Welcome from IN.
BC
