Author Topic: is it possible  (Read 1228 times)
Offline cb650 bobber
  • Expert I ain't no stinken
  • stupid gloripope
is it possible
« on: November 02, 2007, 06:27:56 AM »
To make a 1980 cb650 a converted fuel injection motor without going broke...answers ideas anything.
"I make a point of staying right at the edge of poverty. I don't have a pair of pants without a hole in them, and the only pair of boots I have are on my feet. I don't mess around with unnecessary stuff, so I don't need much money. Von Dutch
Offline Soos
Re: is it possible
« Reply #1 on: November 02, 2007, 01:35:28 PM »
that all depends on the depth of your pocketbook.
l8r
-=≡ Soos ≡=-
(61mm)652cc 1979 cb650
Offline edbikerii
    • Gallery
Re: is it possible
« Reply #2 on: November 02, 2007, 03:57:43 PM »
If your goal is to make it run right, just fix the carbs.  They work fine when they work properly.  Also, the few hours you'll spend fixing the carbs will certainly return a much greater benefit than the hundreds of hours you'll spend researching and assembling parts, tuning, trial and error, etc. for FI.
If you still need to go with FI for whatever reason, then look at MegaSquirt.
SOHC4 #289
1977 CB550K - SOLD
1997 YAMAHA XJ600S - SOLD
1986 GL1200I - SOLD
2004 BMW R1150R
eldar
Re: is it possible
« Reply #3 on: November 03, 2007, 08:49:00 AM »
As people have shown in the past, it is always possible to make mods to anything. It just depends on your skill and monetary stocks. You would probably have to do more of a throttle body injection where the fuel is squirted directly into the air stream to mix. This would then NOT require any major head work. I think the main issue is the control of the fuel metering.
Offline tomkimberly
Re: is it possible
« Reply #4 on: November 03, 2007, 08:59:37 AM »
If you have CV carbs you need to locate a set of VB44-B or -C carbs with screw in idle jets. All your carb problems will go away. They were used on the 82 CB650's.
Tom
