Author Topic: Where to get internal turn signal switch part...?  (Read 975 times)
Offline carl
« on: November 02, 2007, 08:52:45 AM »
Ok - finally got my bike ready to tune up and ride a little bit - and my friggin' turn signal switch busted. It's the little plastic piece inside that holds the 'slider contact' - of which the thumb lever slides from side to side. The rest of the switch is fine.
Anyone know where to get this little part? I've looked around a bit, and all I can find is to buy a whole new switch/lever piece, which seems a little pricey. I just need that tiny piece of plastic.
Arrrggg,
-Carl
p.s. TIA!!!
Re: Where to get internal turn signal switch part...?
« Reply #1 on: November 02, 2007, 09:45:03 AM »
Only piece available seperate is the bit you put youre thumb on (if you can find a parts list with the number!) Otherwise yes its a complete switch, but at least a lot are the same
