Author Topic: Carb bowl gasket cement  (Read 1128 times)
WHALEMAN
« on: November 02, 2007, 03:28:29 PM »
Does anyone know the best glue or gasket cement to use on the float bowl gasket. Nothing I have used over the years was as good as came stock. Everything I have tried either expands after a few months or softens and allows the gasket to slip or pull away when removing the bowl. Anyone found something as good as Honda's?
Re: Carb bowl gasket cement
« Reply #1 on: November 02, 2007, 03:38:01 PM »
Gaskacinch from Edelbrock.
Offline azuredesign
  • Knupping pin
« Reply #2 on: November 02, 2007, 03:40:29 PM »
Man, I've never used any cement on those gaskets and would be concerned about contaminating fuel  and clogging jets with the adhesive. I've always thought that friction was the reason that some gaskets stayed on the carb body when the bowl was removed. I'd be interested to know if folks are using adhesives with these gaskets.
Offline Bodi
« Reply #3 on: November 02, 2007, 07:15:47 PM »
for the O-ring gaskets, I use automotive weatherstrip adhesive. I don't think gas dissolves it, may be wrong though. I have to use lacquer thinner plus acetone and some elbow grease to get the Honda stuff out. I don't know what it is either.
