Author Topic: Best way to remove side cover bolt  (Read 951 times)
Offline fmctm1sw
« on: November 02, 2007, 06:24:12 PM »
I'm planning on doing my side covers right this time when I paint them.  What I want to do is remove the bolt on bottom that attaches it to the bike.  Figuring out how it comes off was easy (just push that little pin out).  When that pin doesn't come out, what is the best way to get it out with the least amount of destruction?  I considered cutting both ends off to get the spring off but I'm left with a cut off piece in the middle of the bolt.  Can I simply drill the rest out?  Then what about a reassembly solution.  Could an appropriately sized cotter pin or nail be pressed into it?  Someone's had to do this before...
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline rhinoracer
Re: Best way to remove side cover bolt
« Reply #1 on: November 02, 2007, 08:32:17 PM »
Can you be more specific? Which bike, cover?
Baja native.
Offline fmctm1sw
« Reply #2 on: November 03, 2007, 06:56:24 AM »
350F covers.  The one over the battery and the turn signal flasher/voltage regulator/etc.  I'll get a photo later this morning...
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
