Author Topic: Blog: 736cc Builds His Pipe Dream  (Read 51461 times)
Offline 736cc
Re: Blog: 736cc Builds His Dream Bike
« Reply #125 on: November 25, 2007, 10:27:59 AM »
...and a forum member.
...small world, eh?
NICE work on the disc, I'll be sending triple discs for swiss-cheezing this winter.
« Reply #126 on: November 25, 2007, 11:21:30 AM »
Really been wondering.. How much did it cost to get your unnumbered pipes shipped from Japan ??
$250 and it arrived at my front door 36 hours after I clicked the mouse.
Wow thats cheap! I had a set of 4-4 pipes sent to me from within the states that cost $125!! Good deal in my opinion.
Cheers
Andy
Offline KB02
« Reply #127 on: November 26, 2007, 05:41:03 AM »
Wow. That disk is so pretty. I wouldn't want to even use it just to keep it looking that way.   ;)
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
Offline 736cc
Re: Blog: 736cc Builds His Pipe Dream
« Reply #128 on: November 30, 2007, 06:15:55 AM »
   Front Caliper
 One of the landmarks of the 1969 CB750 is it being the first motorcycle to be equiped with hydraulic front disc braking. Early CB750's came equiped w/ a silver front caliper. I did not take "before" pics but it was in fairly typical condition; bleeder, caliper bolts, piston were all frozen from sitting unused for years. Heating the caliper directly w/ a torch persuaded the bleeder and bolts to free-up. The piston was forced-out by removing caliper B clamshell and hooking-up brake lines and a master cylinder, and pumping the brake lever to hydraulically push piston out. Remove o-ring seal inside caliper w/ a pic, spray in brake cleaner and scrub with a toothbrush ridding the old gummy deposits, then polish inside barrel w/ fine emery. Ditto w/ piston and seal, which were in very good condition. Lube inside of caliper w/ brake fluid, replace brake-lubed seal, slide piston in. If re-using pads, make sure they are sanded on all sides and easily slide in w/o restance, otherwise brakes will hang-up and drag on disc.
 Wipe down caliper and hanger w/ acetone, squirt w/ aluminum spray paint to make it look fresh.
« Last Edit: November 30, 2007, 11:39:50 AM by 736cc »
Offline JLeather
« Reply #129 on: November 30, 2007, 06:27:40 AM »
What's the difference between that caliper and a later one, beside the color?  If you sandblasted a black one back to silver how would you distinguish it from a sandcast?
« Reply #130 on: November 30, 2007, 07:40:34 AM »
Note the square shoulder on the outer edge of the Aluminum disc center..used on Ko,s.
I should have few calipers around and an early mc  with the lever adjuster.
Offline 736cc
« Reply #131 on: November 30, 2007, 11:27:11 AM »
  Very earliest calipers have less fins and details; the numbers next to TOKIKO change as production moves along. It'd be very hard to tell difference between a K0/K1/K2 caliper except color.
Offline 736cc
« Reply #132 on: December 07, 2007, 10:59:51 AM »
   After pulling a couple of all-nighters, the restoration is complete. That last 10% of a restoration is always 90% of the work, and suddenly, its done. All that remains is adding fluids, the initial start-up of the fresh motor, carburation synch, and a test ride. After all this, its definately time to decompress just in time for the holidays. This motorcycle will be on display in New York City at the CYCLEWORLD International Motorcycle Show Dec 28-30. Hope to see you there! Happy Holidays!
« Last Edit: December 07, 2007, 11:04:43 AM by 736cc »
Offline scunny
  • don't call me expert
« Reply #133 on: December 07, 2007, 11:13:30 AM »
very nice work, words aren't enough so I'll just say thank you for the blog.
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
« Reply #134 on: December 07, 2007, 12:41:34 PM »
Another great job. Congratulations and have a fantastic show. Are you putting a price tag on it for the show or are you hanging on to it? If you get bored you can always head to Colorado and help me polish parts  ;D
« Reply #135 on: December 07, 2007, 01:53:48 PM »
Nice job indeed. Another beauty created.... or recreated!
Offline chrislib
« Reply #136 on: December 07, 2007, 03:40:52 PM »
Wow thats nice. I`d love to go to the show in Manhattan but can`t. Maybe I`ll se ya riding it around the Island sometime??? (I`m in Bellport)
Chris...closet Idlefiddler
#1975
1973 CB750K...CANDY BACCHUS OLIVE
Offline Roach Carver
« Reply #137 on: December 07, 2007, 04:30:20 PM »
b e a uteeful
Offline 736cc
« Reply #138 on: December 07, 2007, 06:42:51 PM »
  Yes, it will be sold that weekend at the NYC show. 75,000 motorcycle enthusiasts will walk past it, and many will be looking to buy a motorcycle. An impluse buy from a celebrity would be nice!
« Reply #139 on: December 08, 2007, 08:19:46 AM »
Shows are fun but can be exhausting especially if you're working it the whole time. Do you have your own booth? And, as always, pictures are expected especially with the new owner. If you need any references there are about 4000 here.  :D
Offline mgmuellner
« Reply #140 on: December 08, 2007, 01:43:14 PM »
Wow, nice work!  Very inspirational
73 CB750
69 CB350
73 RD350
73 z50 (2 of em)
01 SV650
Offline 736cc
« Reply #141 on: December 09, 2007, 08:12:46 AM »
Offline mikedialect
  • cbjunky
    • Mike's Metric Vintage Honda
« Reply #142 on: December 09, 2007, 08:21:53 AM »
So, all that love, attention to detail and so on and you're going to sell it? why sell? (no offense intended!)
SOHC4 Member#44153
www.mikesmetric.com | www.mikedialect.com
Offline 736cc
« Reply #143 on: December 09, 2007, 08:37:29 AM »
  Consider the plite of a starving artist who puts everything into his work; he creates a painting or sculpture, puts it in an exhibition, and is successful if it sells.  Besides, how else would I be able to buy another to restore? To me, the journey is more important than the destination.
« Last Edit: December 09, 2007, 08:41:13 AM by 736cc »
Offline mikedialect
  • cbjunky
« Reply #144 on: December 09, 2007, 09:12:20 AM »
*nods* preaching to the starving artist here. I understand. I do keep a few of my pieces, but I let a lot of them go, too. I suppose it helps that you have a few already. I just don't have a bike that pretty, so I was trying to wrap my head around it personally. I'm too young and have too little money from all the money I borrowed for college to ever aspire to own a sandcast, so I will admire from a distance ;) I do understand, though.
SOHC4 Member#44153
« Reply #145 on: December 09, 2007, 03:10:39 PM »
  I take inventory of everything that comes w/ the motorcycle. This motorcycle is an EXCEPTIONAL basket case and came w/ the motherload of rare original parts and a fantastic cache of nos bits, it literally filled my van. Previous owner (and my very good buddy) has been accruing and hoarding parts for 15 years, and knows the sandcast esoterics as well as anybody. I've been "handed the torch" for me to finish. I cannot think of a more enjoyable and personal mission to accomplish, and I am determined to give it my very best effort to date. I've been doing this for 10 years, owned and restored 40 early CB750's, and have learned there's no down-side in doing things right (except breaking the bank- but this certainly is a blue-chip investment).
  Motor was rebuilt, aluminum polished, frame powdercoated, all the chrome re-plated, motorcycle just needed that BIG final push. The inevitable missing and INCORRECT parts must be sourced. And it will be CORRECT, that is the only direction to go.
  The Honda Parts Book contains every single part including sizes of screws/nuts etc. An invaluable reference tool, it also has part #'s which you can simply hand to your friendly neighborhood Honda parts guy. Honda will carry a suprising percent of what you need (except the really early GOOD stuff- for that you will need a parts bike (or 2), buy/swap w/ people in the loop, shop at YAMIYA, and bid victoriously on ebay).
No doubt about it, we need a drooling emoticon.............
736: you have the book in this picture that can answer the question I have been chasing for quite a few years, as it is the one that stopped when the bearing in question also disappeared, so here's the question:
What part number is shown for the final drive bearing in that book?
It is a 1-row bearing in the K0-K3 (early) engines, became a 2-row bearing sometime during the K3 (although I have seen the 2-row in K2s, too). Also, the final drive shaft is different to accomodate the narrower bearing. I need a 1-row final drive bearing, do not wish to give up the 1/2 HP the 2-row eats up. They are not interchangeable, nor is the shaft! (You must change the shaft to use the 2-row, and vice-versa.)
You K0 restorers are bothering me....I'm beginning to get the itch to do resto K2s (preferably the early ones, as only 800 or so were built...).
Offline 736cc
« Reply #146 on: December 09, 2007, 06:29:45 PM »
Hope this helps..
My old K2 was a sweet bike. The early K2's were sorta like late K1's, ie: had the K1 forks etc.
Offline DarkRider
« Reply #147 on: December 09, 2007, 06:46:42 PM »
Very well done resto man. Paulages..you do work on the brake rotors? just wanted to make sure i read the earlier posts rght..
'84 Chevy C10
'73 MGB Roadster
'69 Ford F250
Quote from: heffay
Offline paulages
  • 1976 cb735
    • DOOMTOWN RIDERS P.R.M.C.
« Reply #148 on: December 09, 2007, 07:00:50 PM »
no. it's speedracer741 who does. he is from portland though--always has a listing running on ebay.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1976 CB550 (590cc) road racer
1973 CB750K3
1972 NORTON Commando Combat
1996 KLX650 R
Offline DarkRider
« Reply #149 on: December 09, 2007, 07:06:30 PM »
ah ok cool..wanted to be clear on what i was reading..thank you for the heads up
'84 Chevy C10
'73 MGB Roadster
'69 Ford F250
Quote from: heffay
