Author Topic: speaking of 2 strokes i just got my first one...(pics now posted! 17/12/2007 )  (Read 5165 times)
Offline bill440cars
  • Feeling More & More,
  • Tryin' To Slow Down "Time"!
       Hey Chris.  Doesn't seem like a bad start to me! ;) Looks like you should be "Tripling" in due time, what do ya think?
                               Later on, Bill :) ;)
Member # 1969
Man, I wish I had a H2 750, my life is way too quiet right now! ;D
Offline DarkRider
Chances are it should be ready to rock and roll by spring. A friend of mine may have the wiring harness i need but he isnt sure..if not we will probably patch up the one thats on the bike and relocate the key swtich as well. The wiring is the thing that has Chris most worried about the bike..otherwise hes convinced i stole the thing lol.
'84 Chevy C10
'73 MGB Roadster
'69 Ford F250
Quote from: heffay
Offline DarkRider
Here are some clearer pics of the bike..the ones taken earlier were taken when the camera was cold..so quality suffered a bit..
My friend on the Kawi triples board does have the harness...he wants the rear fender off of the bike for his and i dont like the appearance of the fender on mine anyways so im trading him the fender for the harness and some other goodies...
Heres a rough idea as to how the bike could look very soon..Namely the H2 style graphics..
'84 Chevy C10
'73 MGB Roadster
'69 Ford F250
Quote from: heffay
Offline bill440cars
       Sounds good Chris! One thing that concerns me about multi cylinder 2-strokes, are the crankshaft seals, especially the center seal.
Lots of Luck with that one guy! ;)
Member # 1969
Offline DarkRider
the upside of this bike is that it has a rebuilt engine. Probably has less then 2000 kms on the engine rebuid itself. because it was in much th same conditon as to when i got it when the po got it from his uncle. Except wrapped up just after repaint and rebuild. it was disassembled partly to redo the carbs and thats how i got the bike.
'84 Chevy C10
'73 MGB Roadster
'69 Ford F250
Quote from: heffay
Offline bill440cars
                Sounding Better All The Time, Chris! 8) ;)
                                Later on,Bill :) ;)
Member # 1969
Offline Pwfyrcat1
  • What I'm doing when it's warm
Looks good for $100
Just because you can, doesn't mean you should;)
2002 Yamaha Warrior, solo/souped/slammed/fast
2004 Yamaha V Star Silverado, 'The Sedan'
1992 Yamaha TDM 850
1975 Honda CB400F basket case that wants to be something
Offline DarkRider
hehehehe...Xmas for me soon enough...a nice big box o parts headed my way...
Front fender w/all hardware needed to install
complete wiring harness
oem tie straps to attach harness to chassis
turn signal ears
rear shorty fender
rubbers for side covers
ignition switch with key
and shifter
all for free since the guy wants the long rear fender from my bike for his.
'84 Chevy C10
'73 MGB Roadster
'69 Ford F250
Quote from: heffay
Offline bill440cars
turn signal ears
rear shorty fender
and shifter
      Looks like the bike is coming together "Pieces At A Time." :D ;)
That IS cool that you have things like that happening though. Tends to cut down on The Search For Parts where ever you can find them. :) Keep us posted Chris. ;)
Member # 1969
Offline DarkRider
Its now basicly just reassemble the bike with the right parts...since i will have essentially everything needed to get it to running except for a battery
'84 Chevy C10
'73 MGB Roadster
'69 Ford F250
Quote from: heffay
Offline bill440cars
         What, you couldn't squeeze a battery out of the deal? >:( ::) ;D
    Just kidding, sounds good Chris! 8) ;)
Member # 1969
Offline DME
Nice deal, wouldn´t mind getting my hands on a Kawa twostroke myself  8)
By the way, isn´t that front wheel on back to front? Looks like it should have the brake plate on the left side to run the brakewire backwards...
Just be careful on your first run so that drumbrake doesn´t lock up on you.
Cheers
Dan
Offline RRRToolSolutions
  • I love old Japanese bikes!
yes, that cable is backwards and must be corrected. The wheel has to be turned 180 degrees so the cables come off the left side.
Gordon
« Last Edit: December 23, 2007, 05:47:58 PM by Ilbikes »
Kaws, Hondas, Yamahas, and Suzukis - especially Kaws
Offline DarkRider
Yep...the previous owner..is turning out to be an idiot when it comes to this bike...the forks and wheel will be corrected when the oil and front fender are installed.
'84 Chevy C10
'73 MGB Roadster
'69 Ford F250
Quote from: heffay
