Author Topic: The 1970 Daytona CR750s.  (Read 270259 times)
  • Moderator
Re: The 1970 Daytona CR750s.
« Reply #600 on: September 10, 2010, 02:06:09 PM »
I got the bumph on the cap today, It's £52.50 + VAT and postage. No VAT charged outside EU.
Sam. ;)
Offline H2Eric
« Reply #601 on: September 11, 2010, 06:07:01 AM »
Sam. ;)
Hi Sam
Put me down for one of those fuel caps.
Cheers
eric
Honda CR750
Honda CB750K3
Kawasaki 750H2B
Suzuki GS750
Honda CB175
Honda CB350F
Yamaha R1
http://forums.sohc4.net/index.php/topic,94588.0.html
Growing old is mandatory, growing up is optional.
Offline napoleonb
« Reply #602 on: September 11, 2010, 08:53:53 AM »
Sam,
I would also llike to have one of those, have you already got a photo of the part?
Offline lordmoonpie
    • Moonpie
« Reply #603 on: September 13, 2010, 09:55:46 AM »
Sam. ;)
Who from Sam - where do we send the wonga?!  ;)
1994 Ducati 888 SP5
1951 Ducati 50cc Cucciolo
1981 Yamaha XV750 SE
  • Moderator
« Reply #604 on: September 13, 2010, 10:28:16 AM »
I was scared of asking for a photo after you mentioned the leaver ::)
Sam.
Offline napoleonb
« Reply #605 on: September 14, 2010, 03:34:46 AM »
Whilst we are on the subject of Fuel tanks and everything belonging to it...
I recently bought an fuel tap along with some other parts.
In the partslist I have got are the following parts stated:
Carb. Assy., CR            16100-300-970
Carb. Assy., CR            16100-300-971   already on the shelf
Insulator A            16211-300-970
Insulator B            16212-300-970
Cock Assy., Fuel            16950-300-970   just delivered
O Ring, 125x35            16997-300-970
Tank Comp., Fuel            17500-300-970
Clip, Fuel Tube            17502-300-970
Band, Fuel Tank            17503-300-970   is this the other part on the photo?
Sponge, Tank            17504-300-970
Pad, Fuel Tank            17505-300-970
Tank Comp., Fuel            17600-300-970
I have already got an fuel tank made in Germany which should resemble the original as much as possible. However the "lump" on the bottom side is not an accurate one.
Could somebody show me some pictures of the other parts wich are stated above and the correct form/shape of the bottom lump.
I have already seen that there is some sort of boss around the Cock Assy and it should be fixed by bolts or studs (i suspect the latter)
Thanks in advance
Offline napoleonb
« Reply #606 on: September 14, 2010, 03:40:20 AM »
These are the photo's which a deem most likely to be original (Kit at least)
Were there much differences between the kit and factory bikes on the area of the bottom lump?
Offline napoleonb
« Reply #607 on: September 19, 2010, 09:02:20 AM »
Is there nobody among the regular visitors who can clarify antything?
I am assuming the bottom lump of the fuel tank to be longer for the Dick Mann bike and the rest of the dimension to be the same.
How is the back part of the tank secured with rubbers?
Is that with the Pad, Fuel Tank 17505-300-970 and does anybody know a part which resembles this as close as possible?
  • Moderator
« Reply #608 on: September 19, 2010, 12:01:21 PM »
I can't recall the detail of the sump as I like a lot of people never saw the Daytona tank.
The tank on the one I built was copied from a kit tank but with a Monza filler cap.
The tank is secured at the rear by the rubber and wire strap which you posted before the tank pictures.
As I never saw a full list of kit parts with numbers, I am at a bit of a loss about the pad and sponge.
One of them will be the cushioning that goes in the recess on top of the tank for the rider to rest his chin on.
Sam. ;)
Offline CPHjimm
« Reply #609 on: September 22, 2010, 04:25:21 AM »
Nap, Thats quite some impressive tank you got made there!! hope you get it sorted out. I have no idea and having a hard time just figuring out if I should go left or right with my own project  ::)
\m/ [(-_-)] \m/
Offline napoleonb
« Reply #610 on: September 22, 2010, 06:03:34 AM »
Jimmy, that's not mine unfortunately..
Offline lordmoonpie
    • Moonpie
« Reply #611 on: September 23, 2010, 04:36:36 AM »
Sam. ;)
If you want a chin pad sponge, head on over to the CR750 resource page at ww.moonpie.co.uk ;D
1994 Ducati 888 SP5
Offline napoleonb
« Reply #612 on: September 23, 2010, 05:36:35 AM »
I already found that part, assuming that's the Sponge, Tank 17504-300-970
Yesterday I had a chat with Paul mcGhie he is going to hook me up with the other part.
It will take him a few month's to let this part be reproduced but I've got the time.
So my mysterie is solved.
  • Moderator
« Reply #613 on: September 29, 2010, 03:43:24 AM »
Sam. ;)
I didn't bother asking for a photo of the cap as Simon lordoonpie had already had dealings with the company and was not impressed with their products.
At the weekend, I met another guy with one of their caps and got the same responce, CRAP.
Sam. >:(
Offline napoleonb
« Reply #614 on: October 27, 2010, 04:48:19 PM »
Proceeding my way of adapting my frame, the next question arose.
I know there is a bush welded into the frame for the right side gear shift conversion.
Do any of you have the dimensions of that bushing (I am assuming it is just cilindrical) internal diameter should be sufficient to determine the bearing.
Which if I am not mistaken is no 5 in the picture down below.
But if any of you have the info to complete the picture above (part numbers or dimensions) I would be very gratefull.
Nap
Offline napoleonb
« Reply #615 on: November 01, 2010, 10:31:59 AM »
Anybody who's got a clue?
Offline ttr400
    • ttr400 Projects and Billet parts.
« Reply #616 on: November 03, 2010, 03:47:56 AM »
Hi Nap,
I am busy doing the same thing to my CR. I can't help with any part numbers, but have worked it out from pics. when I am a bit further along and have some parts made I will post some pics.
Kevin
CB400F- 492 Yoshi Racer.
Cb400F- 466 Yoshi Cafe.
CR750 D Mann Replica.
VFR750R- RC30 - 1988.
www.ttr400.com
Offline lordmoonpie
    • Moonpie
« Reply #617 on: November 05, 2010, 04:18:45 AM »
Why do you guys want the gear change on the wrong side? Is it all just in the name of "Daytona replica"??
1994 Ducati 888 SP5
Offline malcolmgb
  • What am I not? an
  • The BEST 400 four by far
    • malcnet
« Reply #618 on: November 05, 2010, 09:34:53 AM »
Hey Simon they maybe cut their teeth on old british race bikes ;D
When my mate bought his new TZ250 back in the 70's he thought he could adapt quickly to left side gearchange after many years using right, after all he had bought a Yamaha road bike and that was easy. The first meeting was a nightmare missed gears and he was all over the place with his braking too, straight to Granby Motors for a longer rear brake hose and he was back to right change.
Malcolm
1977 CB400F
1973 CL175 K7
1976 XL175 - Sold
1964 CL72
1966 CA78
Offline napoleonb
« Reply #619 on: November 05, 2010, 11:58:51 AM »
For me it's formost about the looks of the system but "authenticity" and the technical aspect are also reasons for me to adjust the gear shifter.
Besides photo's I don't seem to get lucky with concrete measurements. And I imagine there there are quite a few bikes with the adaptation in place.
Offline lordmoonpie
    • Moonpie
« Reply #620 on: November 06, 2010, 08:11:33 AM »
I suppose that'e my question Nap - it's just to create an authentic Daytona bike as oppose to a racing 750?
Love the anecdote Malcolm, reminded me of my time racing a 250 ducati - I could change gear OK on the right until I got in a panic and always went the wrong way! How the poor little thing never blew up I'll never know ;D
1994 Ducati 888 SP5
Offline turboguzzi
« Reply #621 on: November 11, 2010, 05:31:19 PM »
This should be posted in one of many the CR threads on this site as it has no relevance here. Mark {kos} has gone into great detail about these bikes on this forum and IS the resident CR expert on this site and probably the most qualified person {on the planet} to do so, trying to "one up" him in someone elses thread is poor judgement in my opinion.
give me a break! i'm not trying to one up anyone. and the ''french'' daytona bikes (or at least daniel mercier's machine, which is almost certainly one of those) have been mentioned on this forum previously. i was lucky to have seen one first hand in 1970, i've been asked to post whatever photography i thought would be of interest, and that's what i did! in exactly what forum do you feel it would be appropriate to post this content?
patrick,
as someone who started his path in this forum some four years ago with wrong foot (and got bashed too) , all i can suggest is that you try and catch first the spirit of the "place". We are not magazine readers reading your amazing personal stories over glossy pages, just simple and mostly poor, (simon LMP aside :) ) guys who love playing and racing sohc4's. This is one of the best and friendliest forum in the biking world and I've been to a few. so just relax and talk to us on eye level, we care more about valve seat cutting angles than VIP stories.
And welcome to our forum :)
TG
« Reply #622 on: November 11, 2010, 05:38:57 PM »
I removed my last post here because i was mistaken, for that i apologise, i thought i was in the CR fork thread. Just remember though, you came onto this site swinging at an established and reputable member who knows these bikes better than anyone so expect some flack, the list of guys that Mark works, and has worked with and his trophy cabinet and achievements speak volumes for the guy and his knowledge of these bikes, nothing you can say will change that fact. And in future use the PM's for personal contact, the email addy is for business only....
plbodden
« Reply #623 on: November 11, 2010, 06:32:05 PM »
patrick,
TG
i don't know tg... honestly... i'm not sure this makes sense to me. i would think a forum should allow as broad a range as possible of content and professional background. i mean, on the face of it, this is in many ways a forum that celebrates history as well as practical and technical topics. it seems to me that well wriiten, detailed in-depth content should have a value here. i don't consider myself a vip at all (although on occasion i've received that treatment as a member of the press and often it kind of bothers me... even if there is a vip sticker on my fiat from having attended the imola 200 revival). but if i were a vip, why should i be made to feel uncomfortable?
maybe this just isn't a good fit. i'm seriously thinking of withdrawing from this whole deal. i've had a very stressful life the last several years and don't need any more angst... especially, through something that has been near and dear to my heart since the age of 14. all the more disappointing, since, by necessity, i had had to set motorcycles aside for several years and felt that now i had time to orient myself back toward that world and that this forum might be a useful part of that process. but maybe i just didn't understand this whole forum business. that's entirely possible. i can certainly direct my energy elsewhere; that's not a problem.
thanks, for the advice just the same.
patrick
Offline ttr400
« Reply #624 on: November 11, 2010, 09:17:24 PM »
Patrick, please keep it coming in any form you desire. I am enjoying your accounts of the Daytona bike as I am trying to build a replica myself, so any info is welcome.
Welcome to the site.
Kevin
www.ttr400.com
