Author Topic: air filters for a cb500  (Read 1010 times)
Offline Drewery
« on: November 06, 2007, 06:38:06 AM »
I haven't come across a replacement paper filter for my 500, so I bought an oil/foam filter off ebay for $26. Is there anything I need to know before I make the switch? As in changing the carb set up etc.
72' CB500K1
69' Triumph GT6 plus
Offline SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
Re: air filters for a cb500
« Reply #1 on: November 06, 2007, 06:48:07 AM »
I had a K&N Oil & Foam filter on my 500 back when. It offered no performance increase (and hence needed no rejetting etc).
I buy my paper filters from David Silvers.
SOHC4 Member #2393
2015 Tiger 800 XRT
1971 CB500K0 (US Model)
« Reply #2 on: November 06, 2007, 08:51:05 AM »
I use the Uni 4055 foam filter in my 550s.  While they do seem to lean the mixtures a smidge (I'm at sea level), I have found any need to change jetting or carb adjustments based on that change alone.  However, if other changes have also been made to the bike.....
rlarkin70
« Reply #3 on: November 06, 2007, 12:34:54 PM »
does that UNI4055 fit inside the air filter box, just like the stock paper element?
« Reply #4 on: November 06, 2007, 03:32:04 PM »
Yes, it is a direct replacement.  Uni Nu-4055.  You should get the oil and cleaner aerosol, too.  Then it is just clean, re-oil and reuse at regular tuneup intervals.
You can get the filter for about $25 if you shop a bit.
Offline neil young
  • striving to be an
« Reply #5 on: November 10, 2007, 01:39:16 PM »
i just recieved a uni foam filter the other day that i bought on ebay.
where do i get the oil (what type of oil)and what is this cleaner i keep reading about ?where do you get the cleaner?
im running it in a 77 cb 550 if that makes any differance
1972 CB500 k1
1974 CB550
1977 cb 550
2008 Triumph Scrambler
Offline neil young
  • striving to be an
« Reply #6 on: November 10, 2007, 03:29:33 PM »
« Last Edit: November 10, 2007, 03:33:19 PM by neil young »
1972 CB500 k1
1974 CB550
1977 cb 550
Priscbs
« Reply #7 on: November 10, 2007, 05:24:19 PM »
I used the oil from my K&N oil/cleaner kit on my Uni.
