Author Topic: removing studs? cb350 case  (Read 2963 times)
Offline mikedialect
  • cbjunky
    • Mike's Metric Vintage Honda
« on: November 06, 2007, 07:27:56 PM »
Looking to remove some studs on a cb350 case... either I'm blind or I missed it in the manual. Any tips appreciated!
SOHC4 Member#44153
www.mikesmetric.com | www.mikedialect.com
Offline crazypj
  • I'm brill, me
Re: removing studs? cb350 case
« Reply #1 on: November 07, 2007, 12:33:16 AM »
Cheapest is to lock two nuts together, smack end of stud to jar threads and unscrew using lower nu against top one..
Nicest stud remover is Snap-On CG500 metric, but its real expensive, particularly if you only doing one case (over $100.00)
 don't use the knurled type that grip studs, they mess them up and make them prone to snap later
PJ
Offline Tim.
  • www.DOTHETON.com
    • DO THE TON
« Reply #2 on: November 08, 2007, 11:30:46 AM »
Are you talking about the cylinder studs?  I replaced a couple on my 550F and used the double-nut technique.  Came out like butter, which perhaps should have been cause for concern.  But, I don't own the bike anymore ;)
Roule comme dans les annĂ©es 70...   Roll as in the Seventies...
Offline mikedialect
  • cbjunky
« Reply #3 on: November 08, 2007, 11:50:18 AM »
I tried the 'double nut' technique to no avail. Maybe tapping the studs- as mentioned- will help aid in the process. I assume a heat gun won't get hot enough for it to be of any use...?
SOHC4 Member#44153
Offline RRRToolSolutions
  • I love old Japanese bikes!
« Reply #4 on: November 08, 2007, 04:54:57 PM »
Are you going to re-use them or replace?
The only sure way to remove them without breakage is heat. Buzz of Dynoman builds and has built a lot of engines. He'll tell you removal attempts without heat is a crap-shoot. Corrosion of dis-similar metals just plays deveil with the threads of both.
My machinist says he's never broke a stud in 40 years and 30 of those are doing 3-4 aluminum heads daily. He heats the part in an oven for 15 minutes at 350 F. He immediately takes the part and double nuts them. "if" that doesn't work - get two large Visegrips and clamp near the bottom in opposing (180 degrees) positions and turn. What you are trying to do is make a "T" handle. Those stud removal tools and other such attemps like the double nut put a side-load on the stud. The T handle effect of the opposing Visegrips will twist even the hardest corroded studs right out.
I've broke a stud on a Kawasaki H2 750 and it cost me a lot to get it out and repaired. I'm a believer and we just replaced every one in my CB750 with heavy-duty numbers.
Good luck.
Gordon
« Last Edit: November 08, 2007, 04:58:22 PM by Ilbikes »
Kaws, Hondas, Yamahas, and Suzukis - especially Kaws
Offline mikedialect
  • cbjunky
« Reply #5 on: November 08, 2007, 08:15:28 PM »
Good luck.
Gordon
Well, I have a 68 cb350 case with a tranny in it that I am going to send to bill440cars and we were looking at ways to make shipping cheaper by having a smaller box, but it's sounding like removing the studs is not a good idea unless you absolutely have to. I don't have a torch and I was REALLY worried that I was going to break the studs when I was double nutting it.
SOHC4 Member#44153
« Reply #6 on: November 08, 2007, 10:10:31 PM »
Mate, if you don't need those studs and all else fails, just bend 'em at right angles and wind them out. I just did it with my K6 engine, (replaced the studs with heavy duty APE items) and it was a piece of pie! Cheers, Terry. ;D
Offline mikedialect
  • cbjunky
« Reply #7 on: November 09, 2007, 10:32:46 AM »
Terry, I know bill wanted these studs for re-use, so I will keep that idea in the tool box if I ever come across ones I don't need:)
SOHC4 Member#44153
« Reply #8 on: November 09, 2007, 01:47:46 PM »
No worries mate, it's like me. Crude, but effective. Cheers, Terry. ;D
