Author Topic: honda cb350f crankcase with cb400f top end  (Read 2069 times)
edmer79
« on: July 22, 2005, 10:53:32 AM »
hi guys,just want to ask for advices regarding cb350f crabkcase with cb400f barrel and cylinder heads.is it possible/
Solid_
Re: honda cb350f crankcase with cb400f top end
« Reply #1 on: January 03, 2007, 04:19:43 AM »
Same stroke and bolt pattern you are a go for launch, the onl thing im not sure of is the tensioner i know there different of the 500/550 but im not sure if 350/400 are the same.
Offline ttr400
    • ttr400 Projects and Billet parts.
« Reply #2 on: January 03, 2007, 04:28:13 AM »
Yes all will fit together, same tensioner etc.  Only small hicup is you will have to enlarge the holes in the top of the 350F crankcase to allow the larger 400 sleeves to fit in. It's not a major job.
Kevin
CB400F- 492 Yoshi Racer.
Cb400F- 466 Yoshi Cafe.
CR750 D Mann Replica.
VFR750R- RC30 - 1988.
www.ttr400.com
Offline vames
« Reply #3 on: January 03, 2007, 06:48:15 AM »
i'd say the only problem is that you'll have to part with the fantastic 6-speed transmission from the 400f
