Author Topic: CB750 Service Bulletin # 42  (Read 2043 times)
Offline Clutch Cargo
« on: November 07, 2007, 03:53:03 AM »
I was perusing the technical documents on this site last night and I came across CB750 Service Bulletin # 42 – Cylinder Head Gasket Oil Sealing (everyone’s favorite topic)
http://www.sohc4.net/files/750_42.pdf
I was aware of the Knock Pin Seals for newer 750 motors, however I was not aware of the recommendation to use eight # 12115-300-305 o-rings as pictured in the TSB.
I wish that I would have seen this bulletin last winter when I had my K1 motor in pieces.
Is this fix still recommended -  ( I could not find 12115-300-305 listed at any of the Honda OEM parts sites)
Is there another o-ring part number that is recommended today?
Mike
1976  CB750K6
1976 GL1000
1994 - ST1100
1985 - HRS21
Offline Sweep
  • Just remember there are no stupid questions, just some idiot asking them.
Re: CB750 Service Bulletin # 42
« Reply #1 on: November 07, 2007, 04:20:46 AM »
I was just through this confusion when building my '76 750 and I used knock pins and seals.
Just out of curiousity, does your k1 leak oil?
'76 cb750K Wiseco 836|ape crank/head|Carillos|CR29s|Dyna 2k|Kerker
'74 Norton Commando Fastback w/belt and bells
« Reply #2 on: November 07, 2007, 04:25:14 AM »
Minor leaking - but very aggravating as I installed HD studs and Honda OEM O-rings.
1976  CB750K6
1976 GL1000
1994 - ST1100
1985 - HRS21
« Reply #3 on: November 07, 2007, 08:19:55 AM »
I think you will find that what happened here is Honda "upgraded" the head gasket so that only the one for the "knock pins" and tube seals was available and this has bigger holes arround the studs in these places so "O" rings were recommended for the studs when the block was not couterbored for the knock pins.
If you had an aftermarket set the chances are that if it was labelled up for the early motors the head gasket would not have had big holes to take the "O" rings
« Reply #4 on: November 07, 2007, 08:39:23 AM »
Had a look round for that part, if you go to a dealer with a proper price list that number may show the "O" ring size even though its discontinued, or measure the hole size in the gasket and the thickness plus a bit
« Reply #5 on: November 07, 2007, 08:43:14 AM »
Be careful (on any O rings)what you choose if you are not sure, just a bit bigger will squish down, may not work. A local rider found this out the hard way, destroyed his can and bearings.
