Author Topic: Clubman fit.  (Read 2753 times)
Offline Killer Canary
  • Typical Bran Muffin
Clubman fit.
« on: July 22, 2005, 03:11:50 PM »
Once I got my clubmans bolted on, the brake line banjo bolt came up against the side of the tach, with the result that an inch of  grip is hanging off the bar end.I would like it to be the same as the other side! I don't want to rotate or extend the bars. Anyone?
Kawi GPz900, H1
Buffo
Re: Clubman fit.
« Reply #1 on: July 22, 2005, 03:15:19 PM »
I have clubmans on my 1978 cb750k8 and they fit fin with a little rerouting of the lines...what are they on?
Don
Re: Clubman fit.
« Reply #2 on: July 22, 2005, 04:26:51 PM »
'78 550K.
Kawi GPz900, H1
Buffo
Re: Clubman fit.
« Reply #3 on: July 22, 2005, 05:02:50 PM »
I found that my clubmans had to be pushed WAY forward to work. with the "points" up as high as the to of the gauges...hope that helps
Don
Offline Uncle Ernie
Re: Clubman fit.
« Reply #4 on: July 23, 2005, 05:39:28 AM »
Some bikes have the reservoir under the tank. Maybe a transplant would work...
Offline Japbikemike
  • Race Bannon
Re: Clubman fit.
« Reply #5 on: July 23, 2005, 05:59:02 PM »
I went with a Kaw. or Yam. master cylinder on my 78 750F with clubmans, they're boxy and banjo off the front avoiding the unfortunate placement of the tach.
"Whats my favorite bike?  The one I'm on Pal, the one I'm on."---Tom Dobson
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
Re: Clubman fit.
« Reply #6 on: July 23, 2005, 08:29:14 PM »
I have clubmans on my 1978 cb750k8 as well. The rubber cover off the master rubs a bit on my tach as well.
It just seems to be the way it's going to be.
nwcafe
Re: Clubman fit.
« Reply #7 on: July 25, 2005, 12:22:19 PM »
clubmans fit on my 750K0 with little problem... there is a little over hang of the throttle grip, but only about 1/8 inch. i have it set up where the 'U' shaped curve of the clubmans is about level, with the points shooting forward instead of up at the sky... the grips are at a nice downward angle and a comfortable riding position. The banjo nestles snug up behind the right turn signal.. the 550 might have a tighter setup than the 750 though.. good luck
« Last Edit: August 24, 2007, 05:35:02 PM by Glenn Stauffer »
HackNslashCustoms
Re: Clubman fit.
« Reply #8 on: October 21, 2005, 08:49:13 AM »
Thanks for the pix! I'm installing these soon and they helped quite a bit in clarifying. I'm sure they helped others too.
Thanks again,
Joel
736cafe
Re: Clubman fit.
« Reply #9 on: October 25, 2005, 04:21:47 PM »
well, the real fix is to replace the master cylinder entirely with a universal nissin m/c, the rubber hose with braided steel lines, and then do this(  http://springvinmoto.com/gallery/view_photo.php?set_albumName=album84&id=DSC00506  ).  it makes you stop in a much shorter distance.  make sure that your fork seals hold oil, as they will blow if they are old.
scott....new guy
Offline Chris Liston
Re: Clubman fit.
« Reply #10 on: October 25, 2005, 04:58:44 PM »
I'm planning on upgrading my master.  Picked up a 93' Kawasaki ZX7R Nissin master on ebay for 20 bucks.  Should work and give me more clearences when I switch to clubmans.
1976 CB550F Cafe in progress
