Author Topic: Beadblasting my tank. Good idea?  (Read 948 times)
Offline fmctm1sw
« on: November 10, 2007, 07:36:30 am »
350F...  I have a tank with a real ratty paint job on it and some small dents I plan on filling out.  Should I beadblast this or should I just sandpaper it?  I already put some paint stripper on it but that seemed real difficult.  I have a small wire brush and drill too.  I think I'll be OK once stripped, I'm good with body filler.  What's the best way?  If I beadblast what do I need to be careful of?  I've never done that.
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline cleveland
Re: Beadblasting my tank. Good idea?
« Reply #1 on: November 10, 2007, 07:57:53 am »
I would have it chem dipped if you are looking for an easy way out.
Offline ColinMc
  • There aint no pickle like a super pickle...
« Reply #2 on: November 10, 2007, 09:53:57 am »
I beadblasted my 76 750k tank no problem, just make sure you take the cap completely off, the petcock out, and plug the holes! Worked great for me. Nice and clean, just had to sand it down and filler, then primer it.
1976 CB750K - Cafe Project...taking forever
1984 Honda MB-5 - MB-8 conversion in process
2001 Ducati 748 - Built 996 motor sleeper
okie
« Reply #3 on: November 10, 2007, 10:37:56 am »
If you bead blast it, you won't want to paint it because it will look so good.  I bead blasted a 350F tank a couple of months ago and was really pleased with the results.    If there is a downside, I haven't found it.  I would suggest using a power sander first to get the striping off, otherwise the striping acts as a mask to prevent the beads from working.
Offline grumburg
  • 74550, 76400F, 72 750 67S90, 68CL90, 65 s65 66 x6
« Reply #4 on: November 10, 2007, 01:35:23 pm »
Took my tank to the radiator shop and had it boiled. Clean inside and out and stripped  to bare metal.
Fonda Honda
Offline fmctm1sw
« Reply #5 on: November 10, 2007, 07:30:39 pm »
Sometimes, my delightfully ignorant approach to wrenching on my bikes bites me in the @$$.  My tank escapade is a prime example.  I went the grinding route.  I was out and picked up a small grinding wheel for my drill.  I went to work as soon as home.  Stripped down to the bare metal on the top of the tank and was real happy.  Used some paint stripper to get along the edges and around the cap.  Lot of bondo on this tank.  Then I got to the bottom of the tank...  You guessed it, pinholes.  Some bigger than a pin BTW.  I didn't even have a chance to put "The Works" toilet bowl cleaner in it yet.  So.. What now?  JB Weld?  Have some of that.  Some "gas tank specific" stuff from Autozone or something?  This is about par for the course for me...
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline ColinMc
« Reply #6 on: November 16, 2007, 09:59:40 am »
Get the POR15 tank lining kit and make sure you get the stuff they also sell for patching holes.
Offline JLeather
« Reply #7 on: November 16, 2007, 10:49:01 am »
DO NOT, I repeat, DO NOT use Kreem.  Bane of my existence.  It will leave you on the side of the road dumping crap from your carb bowls.  The POR15 stuff is great.  You can tape the bottom of the tank so the pinholes can't leak too much filler and coat the inside with the POR.  It works great.  Just make sure you follow the instructions.
Second option is take it to a radiator shop (if you've still got one in your area) and have them fix it.  They have a red coating they use which also works great.
Offline Steve F
« Reply #8 on: November 16, 2007, 01:04:13 pm »
+1
With bead blasting, I was also able to remove a bunch of old bondo that was in the small little recesed areas that sanding would never have reached.  The body guy was very happy to see all the crap removed so he could dolly out the dents and high spots. Saved him a bunch of time, and me a lot of money.  8)
