Author Topic: CB 750 rear shocks  (Read 1729 times)
hogsnhondas
CB 750 rear shocks
« on: November 12, 2007, 01:58:44 PM »
Any help here? I have a 1977 CB750 F. I have a good set of shocks for a 1976 CB500, can I use or load rating not enough? Any other suggestions?
Offline spitfire
Re: CB 750 rear shocks
« Reply #1 on: November 13, 2007, 03:37:09 AM »
Don't know about the CB500 shocks, I used Hagons on my 76 CB750F1 and they look and work great, however I am in the UK.
http://www.hagon-shocks.co.uk/main1st.htm
Cheers
Den
Wirral UK
1976 CB750F1 bought new in 76
1977 CB750F2: Restoration started
1964 BSA A65R: Waiting restoration
My gallery is here: http://www.sohc4.us/gallery/v/members/personal/spitfire/?g2_navId=x5a30f7b6
« Reply #2 on: November 13, 2007, 09:01:39 AM »
Two things to consider with shocks/springs:
1- Travel length.  From memory, I think the Cb500/550 shocks are about an inch shorter than the CB750.
2- Spring strength.  These are rated in pounds per compression length.
The 77 CB750 is a 512 lb bike with a 360 lb. load capacity.  The springs accommodate this load distributed front/rear at an unequal ratio.
The 72 Cb500 is a 403.5 lb bike with a 300 lb load capacity. The springs accommodate this load distributed front/rear at an unequal ratio.
With CB500 shocks you can expect your 750 to sit lower in the rear and bottom out more frequently on uneven pavement.
They will fit on the bike, though.  Don't take any passengers, ride only on smooth roads, and jack the pre-load to max on the springs.
hogsnhondas
« Reply #3 on: November 14, 2007, 05:36:39 AM »
Thanks for your help. I think I will invest in the correct ones. Don't want to cheap on the handling. Thanks again.
« Reply #4 on: November 14, 2007, 08:33:05 AM »
Try the 750 springs on the 500 bodies if you can get them on..
Offline jtb
  • An unlikely
« Reply #5 on: November 14, 2007, 08:36:58 AM »
Hogs, I've got a set that I took off my 77 750F.
John
1977 CB750F
1985 V65 Sabre
hogsnhondas
« Reply #6 on: November 14, 2007, 05:33:09 PM »
What are you lookin at for price? I've priced new A/M one's - not cheap. I just started project and noticed my shocks are not going to do.
What condition, leakage? Where you at?
