Author Topic: I NEED HELP WITH WHEELS....Please?  (Read 1991 times)
tattoo dave
« on: November 13, 2007, 08:05:15 PM »
Does anyone have any information that could help me figure out how to swap the mag wheels on my 78 supersport, to spokes? I know that I must be missing something,this should be easy.....right? I could order some Excel rims and have them laced up....but what about the rear hub? Can I get a used wheel and make it work somehow????
I have what I think is going to be a really great looking bike,even though it is a supersport,with a real unique look. The mag wheels just wont look right in my mind!
Offline FunJimmy
  • Who you calling
  • Vancouver
Re: I NEED HELP WITH WHEELS....Please?
« Reply #1 on: November 13, 2007, 08:25:42 PM »
Wow! You're right, that is an awesome looking paint scheme.
You should be able to purchase complete wheels for a song on feebay.
Everything you need should be available almost all the time.
If you are planning on lacing up fancy alloy hoops then just search for hubs.
They are cheaper to ship because of reduced size & weight.
I just purchased a CB550 rear hub for just that reason and it was only $25.00
Good hunting
Offline mkramer1121
« Reply #2 on: November 13, 2007, 08:34:28 PM »
Disc brake is your issue...You maybe have to sap to a rear drum.  Do some searhcing on the forum, I know that some have done it.
tattoo dave
« Reply #3 on: November 13, 2007, 09:11:04 PM »
Thanks guys, I think that the rear disc is the real issue. I would rather not switch to the rear drum,even though it looks great,the saftey of the disc is hard to give up!? I see all kinds of stuff on ebay,but I just dont know what will work?
The frame, swing arm,lower fork tubes,and other stuff have just been freshly powder coated black.Since it is a supersport,the motor is black,and I just think black wheels with stainless spokes would just set the whole thing off! The tank,fender,seat,and side covers look even better now that there is clear on them. I debated getting some Gulf Oil decals to place on the bike before the clear was layed down...?I have black clubman bars and black headlight brackets.
I will continue to search and dig, I know that there is a way to do this.Carpy put spokes on a yellow SS that he built on his site,I will try to email him again and see if he has any info for me.
Thanks again,
Dave
tattoo dave
« Reply #4 on: November 13, 2007, 09:12:55 PM »
WHITT, will they work on a 78? If so GREAT!!
Offline 78 k550
« Reply #5 on: November 13, 2007, 09:24:02 PM »
the rear mag on the rear is wider then the spoked hub if you kept your 78 swing arm it would be just a matter of spacing it up for alignment of the chain. I went the other way 76 froam but wanted mads. I had to swap out the swing arm also the mag is too wide for the 75-76 swing arm.
Paul
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
tattoo dave
« Reply #6 on: November 13, 2007, 09:46:13 PM »
Thanks everyone! I will start looking for 76f wheels!!!
I will post more pics on my build soon!
« Reply #7 on: November 14, 2007, 03:54:46 AM »
The 78 front discs wont fit an earlier wheel and the earlier complete wheel, with single disc, needs the earlier forks and caliper.
Back in the 70's here in UK there was a firm who made alloy discs that you could bolt onto the hub after you dissasembled the Honda Comstars, if that is what you have, and had spoke holes to lace a standard rim, could probably be made by a machine shop with an indexing head but pricey
Offline greenjeans
  • 1972 CB750K2
« Reply #8 on: November 14, 2007, 04:53:16 AM »
Ahhh.....paint scheme from the 'ol GT40.... was thinking of that for a future project - can't anymore....  Can't wait to see this finished
Offline eurban
« Reply #9 on: November 14, 2007, 05:41:16 AM »
As Bryan mentioned you are going to have issues with your front wheel.  The bolt pattern for the rotors on your Comstar front is different than standard 750, so your rotors won't bolt up to a spoked hub. Spoked K model style rotor(s) are too big in diameter, too thick and have the wrong offset to work/line up with the calipers on your F2/F3 front end.  MRieck made it work on his CB but it took a good bit of machining.  You might ask him what the process was.
« Last Edit: November 14, 2007, 06:39:02 AM by eurban »
wiretender
« Reply #10 on: November 14, 2007, 07:05:28 AM »
Yes, and others who wore Gulf Oil sponsorship colors.
Offline paulages
  • 1976 cb735
    • DOOMTOWN RIDERS P.R.M.C.
« Reply #11 on: November 14, 2007, 09:38:37 AM »
easiest solution: '76 F swingarm and rear wheel, and K0-6 forks and front wheel.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1976 CB550 (590cc) road racer
1973 CB750K3
1972 NORTON Commando Combat
1996 KLX650 R
« Reply #12 on: November 14, 2007, 09:50:16 AM »
75F0 AND 76F1 are identical - might make life a little easier for you
