Author Topic: Metal tag thingy  (Read 1061 times)
Offline NPHLYT
Metal tag thingy
« on: November 13, 2007, 11:58:34 pm »
When did they stop/start putting the metaly tag thingy on the steering tube.... tube on the CB 750 SOHC's?
NPHLYT
1970 CB750 Mutt
1962 Sears Allstate Puch
Offline KB02
Re: Metal tag thingy
« Reply #1 on: November 14, 2007, 04:54:09 am »
Do you mean the VIN plate?
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
Offline NPHLYT
« Reply #2 on: November 14, 2007, 07:22:16 am »
Thats exactly what I mean. I am looking at one and there is no VIN plate, but it looks like there never was one there.
NPHLYT
1970 CB750 Mutt
« Reply #3 on: November 14, 2007, 07:27:15 am »
Then it has been removed or is an early 69. If its early the  last numbers of the serial # should be around 10,000 or less.
« Last Edit: November 14, 2007, 07:51:30 am by 754 »
Offline NPHLYT
« Reply #4 on: November 14, 2007, 07:39:47 am »
The motor is not sand cast.....
NPHLYT
1970 CB750 Mutt
« Reply #5 on: November 14, 2007, 07:53:10 am »
I know they had tags by Nov 69 but dont know when they started.. so is serial # between 7k and 11k ?
Offline mkramer1121
« Reply #6 on: November 14, 2007, 10:21:28 am »
VIN Is engraved in the steering stem on the opposite side of where the tag would be.  SOmeone may have lost is/ground it off at some point, or have removed it for some fraudulent reason.  Look at the actual VIN on the other side and make sure it matches the title.
« Reply #7 on: November 14, 2007, 09:08:25 pm »
If its a UK model Vin Plates were not fitted till 76/77
