Author Topic: changine exhaust mounts.... doable?  (Read 989 times)
Offline mikedialect
  • cbjunky
    • Mike's Metric Vintage Honda
« on: November 14, 2007, 02:31:45 pm »
I looked for it (and if anyone knows where it is on here please point me!) and I couldn't find the answer. I was wondering if it's possible to change the mounts on the early 750 (1973) to take studs for the later muffler mounting. A buddy from here has a 4-2 for a 77-78 that I would like to mount on my 73. Can it be done?
thanks in advace for the link or the advice :)
SOHC4 Member#44153
www.mikesmetric.com | www.mikedialect.com
Offline Clyde
Re: changine exhaust mounts.... doable?
« Reply #1 on: November 14, 2007, 03:28:16 pm »
Yes,
It can be done.
The 73 head has the exhaust stubs which are held in by 8mm countersunk screws. Remove these screws and replace them with the 8mm studs.
You will also need the later exhaust split collars (8) and the later exhaust flanges(4).
You will probably have to fabricate a bracket for the rear of the muffler as the rear supports differ slightly.
Regds Clyde
SOHC4 #1909
Honda CB750 K0(original and unrestored), K1(in pieces), K2(restored), F1(restored), 76 750a (awaiting restoration), 1966 Honda CB72
Suzuki GT750 1972 (restored), Kawasaki Z1 1973 (restored)
Offline mikedialect
  • cbjunky
« Reply #2 on: November 14, 2007, 04:22:49 pm »
Yes,
It can be done.
Regds Clyde
awesome, thanks clyde!
SOHC4 Member#44153
