Author Topic: oil gauge: before I buy...  (Read 1866 times)
Offline babyfood1217
  • The only way to drink espresso is as a
  • I miss my baby...
« on: November 14, 2007, 03:47:16 pm »
I thought I'd feel out my options.  Should I get a pressure or temperature gauge?  Those of you who have them, or better yet, have had experience with both, which do you prefer?  Advantages/disadvantages to either?  I imagine there are kits available to mount these gauges in plug-hole on the engine case, but I also had the idea of mounting the gauge in the cockpit (with the rest of my gauges) and I don't know too much yet about running hose/line from the engine case to the cockpit without issues, and an electrical temperature gauge seems to be my best option.  Also, what temp./pressure range should I be looking for when choosing a gauge?  I'm hoping for a 2" diameter gauge, so any good source reccomendations would be appreciated.  Thanks in advance, and I've keep updates going with the progress.
-Chris
I need help moving my project bike from Wisconsin to Seattle, WA.  Willing to pay well.  Contact if interested.
SOHC member: #438
Project: 1976 CB750K
GSXR forks, Monoshock Rear end, 836 in progress, RC51 pipes, custom frame and everything else.
Offline mikedialect
  • cbjunky
    • Mike's Metric Vintage Honda
Re: oil gauge: before I buy...
« Reply #1 on: November 14, 2007, 06:05:35 pm »
I would recommend the pressure gauge that plugs into the oil galley. Not sure where else you would plug it in without tapping or running an unsightly line.
SOHC4 Member#44153
www.mikesmetric.com | www.mikedialect.com
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #2 on: November 14, 2007, 07:25:40 pm »
I agree on the pressure gauge. That is the most critical element of the two in my opinion. Also, I use mine as sort of a passive temperature gauge. Normally, after getting the engine up to running temp at say 70-90F air temps it runs about 10 lbs. per 1,000 rpm. If gets lower than 10 lbs. it's getting hot. Conversely, today it was only 53F when I was riding and at 3,000 rpm it was running 55 lbs.
Offline cb750k7
  • My CB AKA Charlie Brown...(K8 frame with K6 engine
« Reply #3 on: November 14, 2007, 07:57:31 pm »
Found real friends here !!!
« Reply #4 on: November 14, 2007, 08:02:49 pm »
You could probably take oit your oil pressure lightswitch and run a line up to you other guages.. I think I would trust the pressure guage over a light that tells you "Its too Late!!"
Offline mikedialect
  • cbjunky
« Reply #5 on: November 14, 2007, 10:10:37 pm »
exactamudo... and really not that hard to see.
SOHC4 Member#44153
Offline KB02
« Reply #6 on: November 15, 2007, 05:57:36 am »
I remember seeing, recently, someone who had run a line from the oil gallery up to thge other gauges so the oil pressure gage was with the others. (For the life of me I can't remember where or who). They made it dress with a braided steel line and it didn't look too awful.
Wish I could remember where that picture was...
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
Offline bert96
  • past ride
« Reply #7 on: November 15, 2007, 08:23:46 am »
this is what i did.
QA50 1969,ST-90 1974,mb5 1982,rz350 1983,shadow 1100 1985,vf1000f 1985,BMW K1 1990,shadow tourer 1100 2001,vfr 750 1994,vtr250 199?
  • I miss my baby...
« Reply #8 on: November 15, 2007, 09:55:13 am »
this is what i did.
That's exactly what I want to do.  But I'm curious, what did you use for the line from the oil galley to the cockpit?  All soft line?  Combination of hard and soft?
-Chris
SOHC member: #438
Offline bert96
  • past ride
« Reply #9 on: November 15, 2007, 10:15:48 am »
from the engine to the gauge i use oil line (with weave fabric on it,i don't know the real name of this oil line)with press fitting on both end, and some brass fitting and voilĂ ! ;D
  • I miss my baby...
« Reply #10 on: November 15, 2007, 10:30:53 am »
idea of dimensions of the hose?  oil-resistant, but how about ID/OD?  I'm wondering if I would be able to find stainless steel braided oil-resistant hose out there.  I'm curious how the oil pressure is affected by such a long, soft hose (not worried about it adversely affecting the engine so much, but rather the reading on the gauge.)
SOHC member: #438
Offline bert96
  • past ride
« Reply #11 on: November 15, 2007, 10:37:17 am »
OD 1/2" and ID 3/8" on the line it said "DOT" so i figure it pretty tough.
Offline bert96
  • past ride
« Reply #12 on: November 15, 2007, 10:59:03 am »
Ok,so i took some pics the first one is the oil line,and the second is the gauge pod,i did some recycling,i took the tip of a broken hair dryer,it's made from steel  and it's chrome...perfect! ;D
Offline bert96
  • past ride
« Reply #13 on: November 15, 2007, 11:00:56 am »
 oups!  ID 3/16" ...sorry ;)
