Author Topic: carb issue  (Read 798 times)
wuudey
carb issue
« on: November 15, 2007, 08:36:03 am »
I'm stuck in limbo here - got this74 - 750 with carb issue - started to take apart and clean - got to the last one and the float was stuck and somehow I borke off the stem that holds the float pin.  I got a CHEAP set of carbs from ebay that were supposed to need a slight cleaning.  (this guy must be really filthy in real life) Well the floats are varnised over  and will not turn.  The air mixture srcews will not move at all.  I've already tried drilling and using an easy out and it hasn't worked either - so what do I do now to get this screw out.
