Author Topic: Any good ideas for a temporary fuel bottle?  (Read 4330 times)
scadaman29325
« on: November 15, 2007, 12:37:36 PM »
I've got my tank off my wife's bike but want to run it to adj the carbs...
So, anybody got some good ideas for a temporary fuel bottle?
You know, like the IV bottle in a hospital.
I've seen them on the OCC show and on a web site for $60, but that's a lot for the few times I'll need it.
Thanks in advance, Phil
   And thanks for the forum!
Offline cleveland
Re: Any good ideas for a temporary fuel bottle?
« Reply #1 on: November 15, 2007, 12:43:48 PM »
Cheapest way to go is to just pick up some gas line.  I
used a latter to put the tank on and just ran the line to the carbs.
http://i92.photobucket.com/albums/l30/cb750caferacer/clevelandsvintagecycleparts/100_3111.jpg
edit:  Changed pic to link
« Last Edit: November 15, 2007, 06:23:59 PM by cleveland »
Offline S-Dog
« Reply #2 on: November 15, 2007, 12:46:29 PM »
windshield washer container from a car.
1975 CB750K Bright Orange with 8300miles
1983 GL650 Silverwing Restore project with 17k miles
http://www.NEHondaGuys.info/forums
Offline azuredesign
  • Knupping pin
« Reply #3 on: November 15, 2007, 01:05:19 PM »
20 fl oz soda bottle. Fill it with gas, and screw on one of the adjustable oil dispensers that you can buy for $.99 at the auto parts store. It allows you to adjust or completely turn off the flow from the container. It has a male fitting that allows gas line to be attached to it. Turn it over and punch a small vent hole in the bottom.
You can splurge for $3.99 and buy the dispenser and a plastic container that shows volume measurements and allows more fuel to be added easily. Attach to a microphone stand with boom or hammer together a couple of 2x4s with an arm to hang the bottle from and run hose to your carbs.
P.S. I use the same set up for I.V. bottles when necessary!
Offline gregk
« Reply #4 on: November 15, 2007, 01:23:05 PM »
I went to the garbage dump and got a small plastic tank from a lawnmower.  Works great.
Greg
I don't want it to go like a motorcycle, I want it to go like a rocket!
Offline gerhed
« Reply #5 on: November 15, 2007, 01:26:24 PM »
Windshield washer fluid containers from older VW Beetles.
Very robust and interesting looking, too.
          83 XL600R in CB360 Frame
Offline hcritz
« Reply #6 on: November 15, 2007, 02:17:26 PM »
I made mine from a metal gallon paint bucket from Lowes...soldered a brass fuel barb in the side at the bottom....the handle fits nice behind the grip and keeps it from falling of too.
Total cost $4!
Offline Bido
« Reply #7 on: November 15, 2007, 05:10:12 PM »
I picked up a one gallon plastic gas can and found and found a plastic gas valve that came with a hose and a nipple at a local hardware store drilled a hole in the bottom of the gas can and used a hollow threaded pipe the kind you find in electrical light fixtures some rubber washers and nuts hose clamp and I was good to go cost about $12 good luck.
Bido
1978 CB750 Supersport F3
1981 CB750 K
Offline stresssolutions
  • 4 years on a motorcycle, Time Flies!
  • 03 RoadStar, I miss my Honda
    • bloggy thoughts
« Reply #8 on: November 15, 2007, 05:25:17 PM »
You could use any sort of gas can, including your tank, but I was thinking Boat tank, with the siphon bulb should help to get the gas there.
I mean that you could use a siphon bulb with any gas can, even to suck gas out of your lawn mower.
« Last Edit: November 16, 2007, 03:35:43 AM by stresssolutions »
Enjoying life, one day at a time.
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
« Reply #9 on: November 15, 2007, 06:28:19 PM »
I like that one ;D ;D
scadaman29325
« Reply #10 on: November 16, 2007, 05:04:48 AM »
Very good ideas!
Now you got me brain in gear. (I think its clutch was slipping)
Thanks AGAIN, Phil
scadaman29325
« Reply #11 on: November 19, 2007, 10:13:33 AM »
I found a 'coolant overflow bottle' at Advanced Auto for $7.
Now I have to find hoses, fittings and a valve.
The hose at AA was $1.50 a foot!
Later, Phil
Offline cleveland
« Reply #12 on: November 19, 2007, 10:16:35 AM »
You can get 25 feet at Z1 for $10.  ;)
Offline Raul CB750K1
« Reply #13 on: November 19, 2007, 10:21:08 AM »
I just bought one ready made at www.louis.de with a set of hoses and fittings. 24.99 euro. A little expensive in my opinion, but I needed it quick.
scadaman29325
« Reply #14 on: November 19, 2007, 01:00:10 PM »
By the time I'm through, that's probably what I'll wind up spending on my contraption too...
Later, Phil
