Author Topic: Need some high compression pistons  (Read 5770 times)
Offline Soos
Re: Need some high compression pistons
« Reply #25 on: November 17, 2007, 08:07:31 PM »
If you are seriously willing to spend the money, why not contact arias?
600.00 a set including rings and wrist pins, but they will manufacturer a one of set to your specs.
Had thought of doing this for my 650 in the past... but i'd rather machine down a set of 750 pistons, and get a head job done instead of just pistons...
l8r
-=≡ Soos ≡=-
(61mm)652cc 1979 cb650
« Reply #26 on: November 17, 2007, 08:15:10 PM »
The pistons you showed were 2 ring and M-3,s look like 3 ring.. may be better on the street..
« Reply #27 on: November 19, 2007, 04:49:24 PM »
    M3 racing offers 62mm pistons(Wiseco) for some coin. Not sure of the comp ratio, but judging from the pics on their site I would guess they are high comp racing pistons. If M3 sells'em they can usually be found cheaper elsewhere ;)
That's your answer Mark, but like Sean says,   expensive!!!!!
Sam. ;)
Offline mlinder
  • "Kitten Puncher"
  • Stop Global Tilting now!
    • Moto Northwest
« Reply #28 on: November 19, 2007, 05:40:59 PM »
Sam. ;)
The ones from buzz are $749, so not really that bad....
Need to see what CR those ones at M3 are, but I may go with buzz just because hes been so helpful.
No.
« Reply #29 on: November 19, 2007, 06:16:44 PM »
Looks like for 600 +range you can get what you want..custom made..
 I was sorta thinking that you would not loike a price any higher than an 836 kit. If you are wiling to spend 750, I think you have a few options..
