Author Topic: Looking for photos of CB550K w/rearsets and 4 into 4 exhaust  (Read 1077 times)
Offline L.A. Nomad........
  • 1976 CB550 K
« on: November 15, 2007, 02:36:15 pm »
Show me what you have..........
L.A. Nomad..............
I am a fuel-injected suicide machine! I am a rocker! I am a roller! [I’m an outta controller] I am the Chosen One! The Mighty and the Vengeance! Sent down  to strike the unroadworthy! I'm hotter  than a rolling dice!
Offline FunJimmy
  • Who you calling
  • Vancouver
Re: Looking for photos of CB550K w/rearsets and 4 into 4 exhaust
« Reply #1 on: November 16, 2007, 12:53:32 am »
Currently working on rearsets for a 77 CB550F with 4 into 1.
What are you searching for?
Do you have the facilities to build your own parts?
All you need is desire!
« Reply #2 on: November 16, 2007, 05:00:21 am »
These are half-assed rear sets, back to the swingarm pivot. Enough to be comfortable, not enough to have to sit on "the boys"!
toddkamps
« Reply #3 on: November 16, 2007, 05:17:35 am »
Bwaller, where did you get those semi rearsets.  They are looking good.
okie
« Reply #4 on: November 16, 2007, 05:27:20 am »
Mine are on a 350F but it looks like they would bolt right on a 550 and work correctly with no interference.  They are made from a pair of shifters from salvaged '83 Interceptors.  Of course, I used the brake (right) side peg on the right side so it would fold correctly.  I kept a stub of the original brake pedal so the return spring would still work.  The added bonus is that the rear brake light switch can still be used.  It took a little bit of cutting, bending and welding on the shifters and linkage, but I like my rearsets better than any I could have bought.
« Reply #5 on: November 16, 2007, 06:45:03 am »
toddkamps, these are a mishmash of several parts, 400F brackets and shifter shaft, F3 pegs and gsxr shift lever. The other side I modified a 400F brake pedal to work.
