Author Topic: 1973 750 gas overflow problem  (Read 1451 times)
jimford
« on: November 19, 2007, 10:08:49 AM »
Hey guys, why do my carbs leak gas so bad if I turn the gas valve on??  I just got gas all over my garage.  It has always done this when I used to ride it. I would have to turn valve off really fast when I stopped.  Any suggestions??  The gas is coming out of the float bowls where the hoses attach.  Thanks guys!!
Offline S-Dog
Re: 1973 750 gas overflow problem
« Reply #1 on: November 19, 2007, 10:15:45 AM »
It could be many things.... floats not adjusted right, floats stuck.... Is it all of the carbs or just one?  My carbs were leaking because of a bad sync.
1975 CB750K Bright Orange with 8300miles
1983 GL650 Silverwing Restore project with 17k miles
http://www.NEHondaGuys.info/forums
Offline dusterdude
« Reply #2 on: November 19, 2007, 10:32:58 AM »
if you mean the overflow hoses,check to make sure your stand pipes arent cracked,if they are they will leak like a sieve.
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline Kevin D
  • SE Michigan
« Reply #3 on: November 19, 2007, 01:11:27 PM »
My 71 used to do that. A new needle and seat in the appropriate carb stopped the leakage. I marked the drain hoses with colored tape so I could identify the offending leaker.
I'll second that.
71 CB750 K1
104,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
fatcaaat
« Reply #4 on: November 19, 2007, 04:44:43 PM »
YEs...this is a PIA.  As a matter of fact, I had trouble with my 3rd and 4th cylinder carbs leaking.  Fix one, the other would leak and so on.  What I found out is that i needed to adjust the float height about 1.5mm to get them in spec at 26mm.  Looks to have fixed the issue.  Now...if I could just find some time to rebuild the front caliper.
jimford
« Reply #5 on: November 19, 2007, 05:27:55 PM »
Wow thanks guys!! I love my bike!!  I need to fix this soon!!  Thank you for your help!!
Offline nteek754
  • 1973 K3/750/836/70 1970 750 chopper 1973 cafe
« Reply #6 on: November 19, 2007, 06:03:37 PM »
Hey al,l I built a second bike a few years ago 750K chopper and the first two years I rode it like two or three times, because of the carbs leaking. I finnally  took them off and cleaned the float valve seats AND, replaced the floats. WOW!! got it and  between my other scoot I put like 8000 miles on.  Probably 1000 on the chopper, with no mre leaks. If you know witch one is leaking take the bowl off (gas off) now hold the float up lightly,  gas on if it dont leak its not your seat its your float setting. then you have to tweak the peton on the float best of luck. Craig in Maine
seven fifty four ever its not the destination its the journey Ive been collecting these old dinasours for 33 years . they are quite an ICON
