Author Topic: Idle won't come down at stops . . .  (Read 1896 times)
kawazacky
« on: November 20, 2007, 04:58:27 PM »
So, here's a question. My CB650 is idling high. Really high - at 7000 rpm according to my tachometer, which probably means about 3500-4000 rpms, since my tach reads roughly twice what it should (550 tach on a 650 engine).
I checked the cable returns, and both the throttle cable and choke cable seem to be returning fine. I SUSPECTED a corroded cable, as the bike ran fine in September, before I left it in the backyard for a month due to a bad charging system.
However, if it's NOT a corroded cable, what else should I start looking at? What else could cause this? What could have happened to the bike while it sat in the back yard for a month?
Offline 750goes
  • it will live
Re: Idle won't come down at stops . . .
« Reply #1 on: November 20, 2007, 07:03:59 PM »
Lubricate your linkages and check all the inlet manifold rubbers for integrity - they could be cracked or loose ??
Offline Sweep
  • Just remember there are no stupid questions, just some idiot asking them.
« Reply #2 on: November 20, 2007, 07:15:20 PM »
If you have push/pull cables then see if hitting the throttle in the opposite direction takes down the idle.
If this were a Norton I'd say you have a sticking carb slide.
'76 cb750K Wiseco 836|ape crank/head|Carillos|CR29s|Dyna 2k|Kerker
'74 Norton Commando Fastback w/belt and bells
kawazacky
« Reply #3 on: November 21, 2007, 11:10:44 AM »
It seemed, upon dissassembly today, that all linkages and inlets were OK. I'll know more the further I dig . . . Mike Nixon, who some of you may have dealt with, suggested that the piston carbs' castings are simply wearing out - which would NOT be cool.
Offline my78k
« Reply #4 on: November 21, 2007, 11:36:28 AM »
carb boot airleaks?
Offline Badger 5
    • Gallery
« Reply #5 on: November 21, 2007, 11:41:31 AM »
I had that issue and I looked at the carbs and noticed one of the lock nuts had come loose.  I just retuned the carbs and it was good.
76 CB550K
75 CB200T
68 CL160 (AHRMA R78)
07 Triumph Bonneville Black
75 XS650
kawazacky
« Reply #6 on: November 21, 2007, 01:22:27 PM »
One of the lock nuts where? Inside the carb assembly? It seemed today, when I was tearing the bike apart, that the intake manifolds fit snugly . . .
Offline GoatBaSS
  • Could someone find an
  • To weird to live, to rare to die.
« Reply #7 on: November 21, 2007, 03:02:21 PM »
I had the same prob on RED and I lowered the needles. Amazing. But I know not of your advanced space age 650! ;D
Leethal # 3046?
1972 CB750K/900CC Red Headed Dunstall, 1975CB750FSS Gone BNF: 1974CB500T, 1976CB750K X 2
Offline super pasty white guy
  • I'm not really a
  • 1976 750 F
« Reply #8 on: November 21, 2007, 04:52:57 PM »
I think he probably means the locknuts on the slides.  The ones that you loosen to do the carb balance.
dave
Offline Badger 5
    • Gallery
« Reply #9 on: November 21, 2007, 06:36:46 PM »
dave
bingo
76 CB550K
75 CB200T
75 XS650
Offline GoatBaSS
« Reply #10 on: November 21, 2007, 06:58:52 PM »
Roger! ;)
Leethal # 3046?
