Author Topic: high rpm VS mph  (Read 8113 times)
johhny b
high rpm VS mph
« on: July 24, 2005, 08:56:38 AM »
I have a 1974 CB750.when I ride the rpm seems too high for the speed i'am going,I checked the sprockets, the front is 18 tooth, and the rear is 48. if i remember i'am showing about 7000 rpm and doing 60-65 mph in 5th. anyone  know whats wrong here.
bowhunter
Re: high rpm VS mph
« Reply #1 on: July 24, 2005, 09:17:13 AM »
On my 77, front sprocket is 15, rear is 41 tooth. Sounds like the PO wanted quicker acceleration. That would account for the high tach reading.
Bowhunter
johhny b
Re: high rpm VS mph
« Reply #2 on: July 24, 2005, 09:22:58 AM »
I thought 18 and 48 was standard for this model.
Offline Einyodeler
  • Midnight bugs taste best!!!
Re: high rpm VS mph
« Reply #3 on: July 24, 2005, 09:30:10 AM »
Yes the stock sizes for the `72 - `76 750K`s are 18 tooth front and 48 rear.
That does seem like a lot of revs at that speed though,maybe someone here with that stock setup could see what rpm`s they`re turning.
On my 500 with stock sprockets I`m turning 5000 rpm at 65 mph.
« Last Edit: July 24, 2005, 09:34:02 AM by Einyodeler »
1972 CB500 - 1973 CB500 - 1974 CB550K - 1975 CB550F - 1975 CB750F - 1976 CJ360 - 1983 CR480 - 1970 BSA A65T Thunderbolt
Download Motorcycle Shop Manuals here: http://forums.sohc4.net/index.php?topic=17788.0
Re: high rpm VS mph
« Reply #4 on: July 24, 2005, 09:45:56 AM »
Yes 18/48 is standard for the 74 model and 15/41 is standard for the 77 model.  The resultant final drives are nearly the same due to changes of the 5th gear ratio in the transmission between the two bikes.
69-76 Drive ratios, 5th gear .939,  Final 2.667
77  Drive ratios, 5th gear .969,  Final 2.733
As to your original problem;
Do you have smaller wheels/tires installed?
Is your clutch slipping?
Are your tach and speedometer both original equipment?
Is your assessment of RPM based on solely on tach readings or actual sound of the engine?
Offline Jonesy
  • Shop Rat
Re: high rpm VS mph
« Reply #5 on: July 24, 2005, 09:48:09 AM »
I'd check the items twotired just mentioned. My '73 CB750 turns around 5,000 RPM in 5th going 65-70 MPH.
Do you have a 16 inch Harley rear wheel? They were a popular conversion....
Offline Harry
    • CB500F
Re: high rpm VS mph
« Reply #6 on: July 24, 2005, 10:45:16 AM »
Am running a 500 using 550 sprockets. 6000rpm=120km/h in 5th, which acts as an overdrive, 4th corresponds to standard 500 setup in 5th ie 5000rpm=100km/h (60mph). 5th is good for cruising, but not for acceleration. 3rd redlines at 140km/h, and the acceleration is phenomenal.
« Last Edit: July 24, 2005, 10:47:12 AM by Harry »
Harry Teicher, member #3,  Denmark....no, NOT the capital of Sweden.
johhny b
Re: high rpm VS mph
« Reply #7 on: July 24, 2005, 10:56:31 AM »
I have a 18 tooth front a 48 rear, an 18 inch wheel and a 100 link chain.the revs sound about right for whats indicated, the speed feels about right for whats indicated. the bike sat a long time before i got it, i don't know much about its history.every thing seems to be ok except the high revs.
Offline mph750k6
Re: high rpm VS mph
« Reply #8 on: July 24, 2005, 12:28:24 PM »
Offline mph750k6
Re: high rpm VS mph
« Reply #9 on: July 24, 2005, 12:33:05 PM »
I have a 1976 750 K which I've owned since 1977.  The stock sprockets are 18 and 48. The engine RPM's have always been just over 4000 at 60mph.
Offline Kevin D
  • SE Michigan
Re: high rpm VS mph
« Reply #10 on: July 24, 2005, 12:50:51 PM »
My CB750K1 is stock with 18/48 gears and 1000rpm is worth about 15 mph in top gear so
  2000rpm=30mph
  3000rpm=45mph
  4000rpm=60mph
  5000rpm=75mph
  6000rpm=90mph
  7000rpm=105mph
  8000rpm=120mph
It sounds like either your tach is out of whack or you've got a real bad clutch.
71 CB750 K1
108,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
Offline Bob Wessner
  • "Carbs Suck!"
Re: high rpm VS mph
« Reply #11 on: July 24, 2005, 01:01:54 PM »
Likewise with my K0, as a matter of fact, right on the money with Kevin D's. Though I can only confirm up to 60 mph since I have had little reason to go faster than that, but since it is pure mechanics and gear ratios, I would assume the higher speeds would be consistent also.
johhny b
Re: high rpm VS mph
« Reply #12 on: July 24, 2005, 03:57:13 PM »
I adjusted the cluch and took it for a ride, it shows 6000 rpm at 55 mph in 5th gear.the speedo might be a little slow, i know i was'nt going 90 thougt. i hav'nt ridden this bike much, it sat for years before i got it , trying to work it in slowly. the thing that bothers me the most about it is the hard throttle, is there a fix to lighten it up.
Offline Bob Wessner
  • "Carbs Suck!"
Re: high rpm VS mph
« Reply #13 on: July 24, 2005, 04:14:18 PM »
Have you lubed the throttle cable? That might help.
johhny b
Re: high rpm VS mph
« Reply #14 on: July 24, 2005, 04:20:46 PM »
it's not the cable i think it's the spring, is there a weaker spring i can use
bowhunter
Re: high rpm VS mph
« Reply #15 on: July 24, 2005, 04:44:49 PM »
Maybe you should have someone pace you and get an actual speed reading. Then you'd know if it's the tach or speedo that's wrong.
Bowhunter
Re: high rpm VS mph
« Reply #16 on: July 24, 2005, 05:23:09 PM »
Just a thought. Are you sure the tach is for a 750 and not a 550.  It looks the same.  But, has a different gear ratio inside.
I had the opposite problem you have with your 750.  I got my original 550 with smashed guages.  The only ones I could find were from a 750.  Looked ok, the breaker said they were the same.  I put it on.  I could never get more than 7000 RPM out of that 550 even though it screamed at WOT.  Turns out the tachs have different multipliers. oops.  Don't know why that engine didn't explode...
The multipier is stamped on the back of the tach.  I think I have that 750 tach in a parts bin somewhere.  If you need it, I'll look and find the multiplier stamping.
Offline Clyde
Re: high rpm VS mph
« Reply #17 on: July 24, 2005, 06:21:33 PM »
My 750's run about 4000rpm  for 60mph.
I think twoTired has got the answer. I bought a 550 tacho for my F1 and had to get it recalibrated due to the diferent ratios. I wanted the lighter green colour  for my 76 F1 so it gave me the right look.
The 550 tacho runs a 20:3 ratio and the 750 tacho runs at 4:1
That means if you have a 550 tacho on a 750 it will be reading 6600rpm when the engine is running at 4000rpm
SOHC4 #1909
Honda CB750 K0(original and unrestored), K1(in pieces), K2(restored), F1(restored), 76 750a (awaiting restoration), 1966 Honda CB72
Suzuki GT750 1972 (restored), Kawasaki Z1 1973 (restored)
johhny b
Re: high rpm VS mph
« Reply #18 on: July 24, 2005, 07:04:46 PM »
I just took the tach off. it's hard to read the numbers on the back.the top number is 057200-0720, i think this may be a part number , below that is what looks like 1580 tpm = 10000 tpm , hard to read, below that is a large 3 and another symbol that looks like an N. is this the correct tach.
Offline Bodi
Re: high rpm VS mph
« Reply #19 on: July 24, 2005, 07:49:08 PM »
No.
Re: high rpm VS mph
« Reply #20 on: July 24, 2005, 07:50:07 PM »
Here's the number for the one I took off my CB550 (Read very low) and the parts breaker man said was from a CB750.  It has the light green face for the 76 model.
057200-0770
2500 rpm =10000rpm
9 N
Offline Clyde
Re: high rpm VS mph
« Reply #21 on: July 24, 2005, 07:53:50 PM »
No this seems like it is of a 550. The ratio is wrong. It should be 10000:2500 or 4000:1000.
Are you sure it is not 1500, which gives 10000:1500 or 20:3
SOHC4 #1909
johhny b
Re: high rpm VS mph
« Reply #22 on: July 24, 2005, 08:14:06 PM »
It could be 1500, kind of hard to read. I guess I'll need another tach. thanks to all for the help, it's nice to solve a problem like this.
johhny b
Re: high rpm VS mph
« Reply #23 on: July 24, 2005, 08:50:53 PM »
one last thought, if the speedo is from a 550 ,would that be indicating wrong to.
Offline Kevin D
  • SE Michigan
Re: high rpm VS mph
« Reply #24 on: July 25, 2005, 04:38:36 AM »
To calibrate your speedo use highway mileposts, stopwatch, calculator. Drive at steady 60mph and check time in seconds for 1 mile. Divide seconds into 3600 for true speed.
                      3600/60sec    = 60mph
71 CB750 K1
108,000 miles
Original Owner
———past———
70 SL100/125/150
