Author Topic: Rear Tire Swap 350/400  (Read 1130 times)
Offline Pwfyrcat1
  • What I'm doing when it's warm
« on: November 28, 2007, 03:55:01 AM »
I'm assmbling parts for a rebuild on a 400f.
http://forums.sohc4.net/index.php?topic=28444.0
      just an FYI the vf500 works nicely on 350 twins too,....so does the rear tire, it almost a bolt on swap.
bob
I am interested in what needs to be different, to use a Vf rear end?
I actually sent an email to cafebob with the same question, then thought about posting here.  It's early and I haven't had my wake up drink.
Please someone chime in
Just because you can, doesn't mean you should;)
2002 Yamaha Warrior, solo/souped/slammed/fast
2004 Yamaha V Star Silverado, 'The Sedan'
1992 Yamaha TDM 850
1975 Honda CB400F basket case that wants to be something
Offline Soos
Re: Rear Tire Swap 350/400
« Reply #1 on: November 28, 2007, 04:41:43 AM »
"ding"
l8r
-=≡ Soos ≡=-
(61mm)652cc 1979 cb650
Offline Pwfyrcat1
« Reply #2 on: November 28, 2007, 05:28:48 AM »
Bad Soos! No! No!  Bad Soos! ::) ::) ::) ::)
1992 Yamaha TDM 850
Offline cafebob
« Reply #3 on: November 28, 2007, 10:58:31 AM »
well on the 350 twins, the axle fits perfect.  You will need to make a very thin spacer, (I used a washer).  The big mod is if you want to use the rear disk. (which you need to do to get the spacing right) The caliper slides on a rail mounted on the inside of the right arm.  I just welded a piece of steel stock and it worked great.
ill try to post some pics....
bob
Offline cafebob
« Reply #4 on: December 01, 2007, 01:51:23 PM »
Picks of my 350 im building...keep in mind I haven't cleaned/painted the forks yet.
http://i239.photobucket.com/albums/ff137/cafebob/Tammys%20CB350/DSC01433.jpg
So this is a 1965 350 twin with  VF500 front end and rear tire.  Disks all the way around.
Bob
Offline Pwfyrcat1
« Reply #5 on: December 01, 2007, 02:52:27 PM »
Thanks for posting up the pics
It doesn't look like you have much clearance between the wheel and swingarm.
Did you use stock length shocks?
I did manage to land a complete triple tree on ebay the other day. There are quite a few vfr parts there.
I will look for some wheels come payday.
1992 Yamaha TDM 850
Offline cafebob
« Reply #6 on: December 01, 2007, 03:15:20 PM »
its tighter than stock, but should be fine...I have a pretty big tire on the rim right now.  Just get a whole damm vf500.  I can get non running ones around her for 150-200 dollars...so much cheaper...
bob
