Author Topic: Need info regarding Oil to use for winterizing my CL175 Scrambler  (Read 2529 times)
aussiemel
Hi,
I have searched far and wide to find information about which oil I should use when winterizing my bike.
I have a 1970 CL175 K4 Scrambler, and I need to use an oil that is good for really cold weather.
Can anyone recommend what I should use, and how much?  I don't have a Clymer manual, etc....so can't look it up.
Any help would be appreciated.
Mel
Offline Hope
  • How did I become an
  • SOHC member since '01
Re: Need info regarding Oil to use for winterizing my CL175 Scrambler
« Reply #1 on: November 30, 2007, 12:05:53 PM »
not another oil thread!!!
eldar
« Reply #2 on: November 30, 2007, 12:06:00 PM »
Are you running the thing during winter or storing it? Need to know before anything else.
aussiemel
« Reply #3 on: November 30, 2007, 12:08:30 PM »
I am storing it for winter.  I will not be running it at all.
I wasn't aware there had been other oil questions.....??
Offline dave400
  • Super Lamb Banana
« Reply #4 on: November 30, 2007, 12:12:26 PM »
Oil is an important factor…     it must be taken seriously at all times  ;D
Offline bozo4onion
« Reply #5 on: November 30, 2007, 12:30:15 PM »
Most seriously. Always use less in engines with less capacity.
Offline mikedialect
  • cbjunky
    • Mike's Metric Vintage Honda
« Reply #6 on: November 30, 2007, 12:54:50 PM »
if you're not running it. The cheap stuff. If money IS NOT an issue- use the same stuff you normally do.
SOHC4 Member#44153
www.mikesmetric.com | www.mikedialect.com
Offline mark
« Reply #7 on: December 01, 2007, 10:02:31 PM »
A good blast of fog oil(boat store item) couldn't hurt. follow can directions.
Happy trails.
F you mark...... F you.
Offline RRRToolSolutions
  • I love old Japanese bikes!
« Reply #8 on: December 02, 2007, 05:38:19 AM »
Mel, I don't really see your answer given here. I have a 1968 CL175 and the needs of it are the same. I suggest a motorcycle specific oil in the 10W-30 or 10W-40. I would go to my nearest Honda, Yamaha, Suzuki, or Kawasaki shop and pick their brand. None of the big 4 makes oil - but they do license their names and provide factory warranty for their machines using them. When you buy a brand from one of them, you will also get motorcycle specific oil which is free of the "Energy Conserving" additive packages used in today's automobiles. There is a difference and that's why I suggest a motorcycle specific oil - one carring the CCMC G-5 or JASO MA standards. These will be free of the additives common to cars, but not best for wet clutches. I use only Motul synthetic - but it's a personal preference.
Anyway - even more improtant than what oil - is changing it. You are absolutely right to want it out of the engine. The moisture/humidity of the incoming air/fuel mixture is mixed with the sulfur in gasoline. This generates sulfuric acid during combustion. The PH of the oil will change and turn to a metal surface-eating acid the can/will cause damage. Engines that are run short distances and aren't ran long enough to get rid of all and any moisture are even more susceptable. It's best to change it and kick it through several times - without starting to get a good splash everywhere for it's long rest.
Best of luck to you and enjoy that CL come Spring.
Regards,
Gordon
Kaws, Hondas, Yamahas, and Suzukis - especially Kaws
