Author Topic: Piston Parade  (Read 2643 times)
Offline cafebob
Piston Parade
« on: December 01, 2007, 01:31:40 PM »
Took a picture of a bunch of the 836 kits i had around the shop today.
So from left to right.....
836 Arias 10.5:1, stock F2/F3, Action Fours F2/F3 kit, Arias 12:1 836 kit
direct link to whole album with each piston ready for their close up.
http://s239.photobucket.com/albums/ff137/cafebob/piston%20line%20up/
just for reference purposes.  Maybe Axl wants to add to the one on his site?
bob
« Last Edit: December 02, 2007, 11:12:41 AM by SteveD CB500F »
Re: Piston Parade
« Reply #1 on: December 01, 2007, 01:43:58 PM »
 Here's a big one. ;)
Re: Piston Parade
« Reply #2 on: December 01, 2007, 01:45:35 PM »
Gas ported..I almost forgot that trick!!
Re: Piston Parade
« Reply #3 on: December 01, 2007, 01:52:55 PM »
Yep. That came out of a hillclimber.
Re: Piston Parade
« Reply #4 on: December 01, 2007, 03:04:06 PM »
Well you can't hold a parade without a contingent from the Royal Australian (piston) Regiment?
In the first pic is my newly rebuilt engine with the 836cc 12:1 Arias pistons that Hondaman sent me, just before I crowned it with Mike Rieck's beautiful stage 3 head and Megacycle 125/75 cam.
Below that is a 3rd oversize OEM CB750, CL77 (61mm) high compression, Action Fours 65mm high compression, MTC (?) 64mm 811cc forged, Wiseco 65mm 836cc 10.25:1, MTC 73mm 1060cc, and the last, a "ring in" is a Wiseco 1170cc 15:1 piston for my Suzuki GS1000S. Isn't EBay a wonderful thing? Ha ha, Cheers, Terry. ;D
Re: Piston Parade
« Reply #5 on: December 01, 2007, 04:42:05 PM »
 That's a beautiful thing Terry. My opinion....switch to grade 8 bead. You're a big boy.....I know you can handle the feedback. ;) ;D
Re: Piston Parade
« Reply #6 on: December 01, 2007, 05:58:05 PM »
PS,,,,,,,you're nuts!!! That's a compliment. ;) :D
Offline Peterbylt
Re: Piston Parade
« Reply #7 on: December 01, 2007, 08:22:54 PM »
This is a gl1100 piston after an abrupt stop.
1975 550F SuperSport
1975 GL1000 Goldwing
1979 CM400A Hondamatic
1981 GL1100 Goldwing
1985 CMX250C Rebel
Offline KB02
Re: Piston Parade
« Reply #8 on: December 02, 2007, 05:37:43 AM »
What is Gas porting?
Okay, back to piston Parade!!!
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
Offline JLeather
Re: Piston Parade
« Reply #9 on: December 02, 2007, 05:56:02 AM »
Anyone know what these pistons are?  They're smaller than 836 (~823) and the only markings are "K" stamped into each dome (probably signifying they're for a K motor).  They look about 10.5:1 CR and they dont have dished-in sides.  Oh, yeah, they use these weird flat circlips that coil into place...
« Last Edit: December 02, 2007, 11:14:51 AM by SteveD CB500F »
Re: Piston Parade
« Reply #10 on: December 02, 2007, 09:35:27 AM »
KB02,
Gas porting, you drill holes into the dome of the piston to intersect with the rear of the top ring groove, it uses the compression to fush the top ring outwards.
As far as I know it works short term as it tends to carbon up, should work great on engines torn down frequently..
