Author Topic: Carbon Fiber Nuts and Bolts  (Read 4489 times)
Offline sparty
  • I just play one on TV
    • Gallery
« on: December 02, 2007, 08:27:45 PM »
I spoke with my father-in-law this evening.  He is a materials engineer in the carbon industry and works on some pretty neat projects for a Swiss owned company.  Anyway, his recent project just finished.  He and his company just made a new series of carbon fiber nuts and bolts.  These bolts and nuts are ultrahigh strength 2.4 million psi/lb/in.3 where as titanium is 1.2 million psi/lb/in.3.  Their melting point is around 650 degrees F.  These bolts and nuts can sustain high mechanical loads without shearing, never corrode, dampen vibration and according to my father-in-law are so light that when in the palm of your hand their weight is barely noticeable or 80% less than the same size metal nut and bolt.  So, I asked him if I can get a sample, he said sure.  Now I am wondering if I can get a few in the correct sizes to fit to my bike in some areas.  The bolts were made in hex head, tork head, and allen head.  Where do you guys think I could use these bolts and nuts safely, assuming I can get more than a sample.  My father-in-law also said that F1 race cars are using them in their suspensions and engines, and the military is using them in aircraft so they must be semi-reliable.
Sparty
1972 CB750 K2 Cafe' Style
fuzzybutt
Re: Carbon Fiber Nuts and Bolts
« Reply #1 on: December 02, 2007, 08:37:45 PM »
would axles be too much of a stretch? motor mount bolts, swingarm pivot too?
« Reply #2 on: December 02, 2007, 11:33:04 PM »
I think the tool kit tray, license plate and airbox could fall off without too many drama's Art, so that's the only place I'd use 'em.  ;D
Offline 333
  • Time for change
« Reply #3 on: December 03, 2007, 07:21:54 AM »
You could use them to fasten fenders, chain guard, battery box, even the handlebar and controls. Virtually everything but the engine and exhaust, where heat is an issue.
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
Offline Bodi
« Reply #4 on: December 03, 2007, 07:42:20 AM »
Whew. I think a set of these bolts would likely cost more than a new R1.
There's a writeup here:
http://machinedesign.com/ContentItem/%2062671/Superstrongnutsandbolts.aspx
Now someone just has to make a carbon fibre frame and wheels, and we're all set.
Offline ekim98
« Reply #5 on: December 03, 2007, 07:59:22 AM »
Add some brake disc's, gas tank and a federal grant! ;D ;D ;D   You could probably get a cb750 under 300 lbs. 8)
Patriot Guard Rider - KY. Ride with Respect
78 750k  cafe bike sort of
67 305  Superhawk (working project)
« Reply #6 on: December 03, 2007, 09:23:42 AM »
Yes they would cost more than our bikes are worth, make Carrillo's look cheap!!
change out all the bolts  for 5K or run a gallon less gas , or go on a diet,  hmmmmmm.
Offline tsflstb
« Reply #7 on: December 03, 2007, 10:37:28 AM »
Neat stuff.  I dumped all my bolts in a bucket as I tore the bike down and it got pretty heavy.  There's a good 15-20 lbs of nuts and bolts on a bike.  You could probably shave 10 lbs with these.  Or in my case, I could just lay off the beer and pie for a lot less money.
I'd imagine these bolts are a one time use thing.  Probably wouldn't want to put them in a high-maintenance area.  I think the new R1's have Ti fasteners like this.  They can't be re-torqued.
