Author Topic: Why you should do it right the first time.  (Read 1032 times)
Offline KB02
« on: December 03, 2007, 08:38:44 AM »
Okay, so admittedly this is not a Motorcycle engine. It doesn't have four cylinders, and it's not even an Overhead Cam. BUT, it does go to show a good sense of what can happen if you don't put your engine together right.
The picture below is from my Lawn tractor. It was given to me for free from my Dad who had replaced the head gasket (and that's all he did and I never touched it - it's not our fault. ::) ). Apparently whomeven had the engine apart the last time didn't torque down the connecting rod bolts properly and they worked themselves loose. As you can see by the picture, a connecting rod can only take so much abuse from this kind of situation:
If you look closely in the picture you can see the bolts on the bottom of the rods are loose. This is how I fished them out of the case. I haven't touched them.
A lot of people on this board are super smart and know what they are doing and we all turn to them for advice (TwoTired, MRieck, to name a couple - Thanks, Guys!!) and a lot of us are amateurs trying our hands at wrenching for the first time. This gives an idea of what can happen if the right steps aren't taken. Take your time and do it right, all.
Now, I've got to go see if I can find a connecting rod for a Briggs & Stratton engine. Shouldn't be too hard, right?
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
Re: Why you should do it right the first time.
« Reply #1 on: December 03, 2007, 08:54:26 AM »
Many years back when i worked on leyland diesels had one come in that wouldn't run, when starter used flywheel turned but front pulley didnt!
On carefull inspection found a conrod stuck through the sump, No 3 i believe, so i removed the split pins undid the nuts and took out the piece of crank!!!---when these cranks were re-ground they needed re-nitride hardening but the BIG shop that did the job hadnt bothered.
Nother one was sombody didnt put the split pins in No 4 and the rod came out the side of the block and through the floor of the coach the engine was in---little old lady sat by side of hole nearly had kittens!!
Offline DarkRider
« Reply #2 on: December 03, 2007, 09:05:21 AM »
YIKES!!
'84 Chevy C10
'73 MGB Roadster
'69 Ford F250
Quote from: heffay
Offline my78k
« Reply #3 on: December 03, 2007, 09:28:10 AM »
I don't see any problem...a little JB weld and maybe some duct tape...she will be as good as new!
Dennis
Offline KB02
« Reply #4 on: December 03, 2007, 09:47:53 AM »
Dennis
 ;D ;D ;D ;D ;D ;D ;D ;D
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
