If you use rears only they build into CB400 hubs pretty easy,
PJ
hi crazypj, surely a rim is a rim, neither front nor rear, you just need the correct diameter and width for the application.
yep, a rim is a rim, but only the rears are 18" (all the latest are 19")
You use spoke washers under nipples to compensate for different nipple diameters and angles ( I just make them )
Never had any wheel problems doing it, ( spokes loosening/breaking) even though it sounds dodgy it works.
I didn't come up with the idea of washers, it was a guy I worked with who built a CB350 road racer for CCS competition.
I've only seen them used to prevent corrosion or cut down friction between nipple and spoke heads when using very lightweight rims with alloy nipples ( they do the same thing with bicycles)
PJ
