Author Topic: Wire Harness; 350/400f  (Read 1171 times)
Offline Pwfyrcat1
  • What I'm doing when it's warm
« on: December 04, 2007, 05:50:20 AM »
I know that many parts from the 350 work on the 400.  Does this include the wire harness?
Thanks
Just because you can, doesn't mean you should;)
2002 Yamaha Warrior, solo/souped/slammed/fast
2004 Yamaha V Star Silverado, 'The Sedan'
1992 Yamaha TDM 850
1975 Honda CB400F basket case that wants to be something
Offline Bodi
Re: Wire Harness; 350/400f
« Reply #1 on: December 04, 2007, 08:09:31 AM »
No.
The main problem is the ignition switch, located down at the left on the 350 and up at the triple clamp on the 400. I think the idiot lights are quite different too but that should be relatively easy to sort out.
I don't think there are any other severe differences but I have never set them side by side to see. Since the 400 ignition switch is further along the harness you could maybe cut the wires at the connector and slit the sheath near your switch then fish the wires out?
I have a 400 harness loose, if you want I can lay it out and get a picture for you to compare.
