Well I think it's interesting, but I am easily amused, I guess?
Today I received 2 large boxes today from Hondaman (Thanks for shipping them for me Mark, your packing skills are first class!) containing my latest EBay bargains, a set of (like new) 836cc pistons (probably an "Action Fours" kit) and bored cylinders, a ported head with stainless steel valves, an Andrews "K" grind cam in "as new" condition, cam towers, rockers, cam cover, oil filter cover, nuts and bolts, etc etc. All in all, a bargain for 100 bucks! (plus shipping, boo hoo................)
Now the seller (not HM) said they were from a 1975 "Supersport" drag bike, but on closer inspection, I saw that this couldn't be correct, because the cylinder block didn't have the deeper holes for the sealing rings that all the 750 engines had after 1974, (?) and then on closer, closer inspection, realised that there was no centre front hole for the 6mm bolt that secures the head to the cylinder block on all engines from the K1, so it's a K0 head and cylinder block!
I've never disassembled a K0 before, but I knew about the one less 6mm screw etc, but what I didn't know.............. (hang on to your collective hats) ................ is ................ (drum roll).........................
there are no removable oil jets on the K0 head! There is a depression in the casting, and I presume that you still fit two little "O" rings in there like you do on the end ones, but all there is, is two tiny drillings in the depression, and that's it!
Did you know that? Oh, you did? Well why didn't you tell me? Ha ha, Cheers, Terry.
