Author Topic: testing an engine out of the frame  (Read 4104 times)
Offline gregwaits
  • Damn, riding a CB750 sure is fun!
    • waits music
« on: December 05, 2007, 08:03:28 PM »
With an engine out of the frame, how can I check it out to see if it runs? I have never bench tested an engine so this is new territory for me.
Obviously I need to set up a fuel source and have the battery hooked up, but what else?
Suggestions?
1978 CB750K8; 1970 CB450
Re: testing an engine out of the frame
« Reply #1 on: December 05, 2007, 08:13:38 PM »
If it's not the 750, but the one in your avatar....
...add oil, battery to the points/coils, fuel to the carbs, and a fire extinguisher (or friend with a hose) nearby. The exhausts can actually spit fire without pipes. Noisy, but cool!   8)
Oh...make sure it's held down with something. The front of the engine likes to kick upward.
Offline gregwaits
    • waits music
« Reply #2 on: December 05, 2007, 08:17:20 PM »
If it is a sohc 750 engine, what then?
Offline Bodi
« Reply #3 on: December 05, 2007, 08:31:37 PM »
You need an oil tank connected. Otherwise, same story.
Offline rbmgf7
  • 2>4
« Reply #4 on: December 05, 2007, 09:00:18 PM »
here's what i did...
the engine is strapped to a atv lift and the gas/oil tanks are straddling some saw-horses.
« Reply #5 on: December 05, 2007, 09:32:46 PM »
Are you actually saying that you would not buy the 69 if it does not start..???????????????
and that you are going to spend hours trying to start it there..  THEN..offer them under a hundred bux !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
« Last Edit: December 05, 2007, 10:02:11 PM by 754 »
Offline gregwaits
    • waits music
« Reply #6 on: December 05, 2007, 09:42:57 PM »
Wow, you sure jump to conclusions.
No, I am not saying what you think I said. I am most definitely buying the bike (engine and all). Then after it is home I would like to test the engine out.
(too bad it won't slide into the CB500 frame!)
« Last Edit: December 05, 2007, 09:48:20 PM by gregwaits »
Offline rhinoracer
« Reply #7 on: December 05, 2007, 10:49:26 PM »
If you have the frame I think it's less of a hassle to mount it than to rig a test bench.
Baja native.
Offline gregwaits
    • waits music
« Reply #8 on: December 06, 2007, 12:08:07 AM »
Great point thx!
Offline lhemrick
« Reply #9 on: December 10, 2007, 10:05:39 AM »
Here is a picture of my "Redneck Dyno"!
Don't give up; Rust is only Temporary!
77 Honda CB750
70 Honda CB350 twin
71 Honda CB350 twin
72 Honda CB350 Four
72 Honda CB175
81 KZ550C2
81 KZ750H2
82 KZ750M1 CSR
84 ZN700 Shaft
Online dusterdude
« Reply #10 on: December 10, 2007, 12:39:43 PM »
dude,you`re my kind of redneck.
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline CrisPDuk
  • Christ on a bike! Me, an
« Reply #11 on: December 10, 2007, 07:41:15 PM »
That redneck dyno looks like the rig we set up to test run the V6 from my Ford Sierra before we put it back in the car ;D
We thought we were being smart strapping it down securely to the bench, but the vibrations made the whole bench walk off up the garage ::)  Which would have been OK, if it hadn't been running a high pressure pump for the fuel injection, you wouldn't believe how far a Bosch pump can throw fuel when you give it some freedom :o
Sometimes the stupidity I displayed in my youth astounds even me ::)
Based on my experience with that motor though, I can offer you a tip Greg, if you don't fit the exhaust, make sure you point the exhaust out of a doorway, either that or wear ear defenders and earplugs ;D
1978 CB550 K3
1985 H100S
Online dusterdude
« Reply #12 on: December 11, 2007, 08:16:24 AM »
if you dont fit the exhaust,you`re liable to burn a valve or 3.
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
Offline Cyclone
« Reply #13 on: December 11, 2007, 05:11:06 PM »
My run stand, originally built to maintain air cooled VW motors.
"Life is not a matter of holding good cards, but sometimes, playing a poor hand well"
..Jack London
Offline lostinthe202
  • Quality testing Elite 80's since 1978!
« Reply #14 on: December 11, 2007, 06:27:27 PM »
Hahahahahaha!
+1
'72 CB500
Offline DarkRider
« Reply #15 on: December 11, 2007, 08:03:43 PM »
Im thinking the reason he wants to bench test it is so he can get an idea of the engines condition before fitting it into the frame only to find out it needs a rebuild and have to take it back out.
'84 Chevy C10
'73 MGB Roadster
'69 Ford F250
Quote from: heffay
Offline Lumbee
    • My pics...
« Reply #16 on: December 12, 2007, 09:04:55 AM »
...have we forgotten the handy dandy $20 compression tester?   ::)  A compression test is gonna give you a pretty good idea on the condition of the internals...maybe better...
« Last Edit: December 12, 2007, 09:12:33 AM by The great "Lumbee" »
"I'm not a welder, but I play one on HondaChopper.com"
Offline lhemrick
« Reply #17 on: December 12, 2007, 03:51:58 PM »
The reason I built the redneck dyno is: I have one cylinder of the four that is down some 60 lbs from where it should be and I was told that if it had not been run in a while to fire it up and run it. Seems there were several that think if I do this that cylinder may "heal" itself in time. Does anyone have anything further to add? I'm all hears! Don't want to open it up if I don't have to. nowhatimean!
77 Honda CB750
70 Honda CB350 twin
71 Honda CB350 twin
72 Honda CB350 Four
72 Honda CB175
81 KZ550C2
81 KZ750H2
82 KZ750M1 CSR
84 ZN700 Shaft
« Reply #18 on: December 12, 2007, 04:19:31 PM »
Would you rather install an engine, get it running & insure it to test in, having only the compression numbers?
Or would you rather see it running and know whether it burns oil or not. then install it?
Need I say more................
