Author Topic: Do I have to disassemble my wheels to have them powder coated?  (Read 2237 times)
ChopperCharles
« on: December 07, 2007, 05:38:55 AM »
I'd like to have my wheels powder coated before I replace my tires. The spokes are rusty and the chrome on the rims is scratched and has some surface rust here and there. Can they just be sandlbasted as-is and then powder coated? I don't care how they look close up, I just care from 3 or 4 feet back. The rust is really fugly. Thanks!
Charles.
Offline tsflstb
Re: Do I have to disassemble my wheels to have them powder coated?
« Reply #1 on: December 07, 2007, 05:50:42 AM »
If you're going to spend the money to powdercoat take them apart.  I don't think it will bond in all those nooks and crannies where the spokes meet the hubs.  You'll end up cracking the powder off in no time.  They won't put it in their oven with bearings and all that grease installed either.  You're better off just blasting it with some Krylon for a quick job.
Offline .RJ
  • homebase in your airspace
« Reply #2 on: December 07, 2007, 06:30:42 AM »
It can be done, you'll just have to take the bearings out.  Its not the best way to go and doing it correctly (new bearings, new spokes, powdercoat, assembly/truing) really adds up.
Offline Steve F
« Reply #3 on: December 07, 2007, 06:35:50 AM »
The heat may have an effect on the spokes and you'll probably end up having to true up the wheel after it comes out of the oven.  Turning nipples after the powdercoating will mess it up.  Take it apart and install new spokes and nipples and have a first-rate job to be proud of.
Offline Patrick
« Reply #4 on: December 07, 2007, 07:46:04 AM »
Powdercoat doesn't stick to chrome well. You will have to rough it up to give the powdercoat something to cling to. Otherwise it will come off in patches.
1970 CB750 K0
1982 VF750S Sabre
1987 VT1100 Shadow
1979 Yamaha XS11
1969 Yamaha DT1B
etc.
Offline sparty
  • I just play one on TV
    • Gallery
« Reply #5 on: December 07, 2007, 08:46:55 AM »
Any powder coater worth their weight will not guarantee their work if the parts are not disassembled and cleaned properly.  If you don't care how they look up close, just rough up the wheels and use a can of epoxy spray paint on them.
Sparty
1972 CB750 K2 Cafe' Style
Offline Tim.
  • www.DOTHETON.com
    • DO THE TON
« Reply #6 on: December 07, 2007, 09:21:39 AM »
I think the conclusion is if you don't care how they look close up, do a nice prep job with some sanding etc. on the rims/spokes and spray them yourself with paint.  They'll probably look better than you expect if you take your time and prep well.
I went all out and had my alloy rims polished, hubs polished, new stainless spokes/nipples, laced, trued, new tires and balanced.  I could have bought another bike or two for what it cost.
Offline jalfonso
« Reply #7 on: December 07, 2007, 11:48:28 AM »
Charles,
When I called one of the powder coaters here in town he said I would need to get the chrome stripped off the wheels before he powder coats them.  Might be over kill but that could be why he has such a good reputation. It's going to cost more to strip the rims than it is to powder coat them.
John
John Alfonso
1974 CB550 Four
1982 750F Super Sport
Offline cafebob
« Reply #8 on: December 07, 2007, 03:37:24 PM »
you can just have the rims sandblasted to remove the chrome...should cost 30 bucks at most.
ChopperCharles
« Reply #9 on: December 07, 2007, 05:16:54 PM »
Okay, that's what I'll do. I'll have the wheels sandblasted to remove the chrome, and then use the VHT brake caliper paint that I used on my TW200's rims...
Charles.
