Author Topic: Carb sync question  (Read 1826 times)
Offline 6adan
Carb sync question
« on: December 07, 2007, 06:25:40 PM »
70 CB750
    Had to replace throttle cable so now I need to sync carbs
 1st.
Dose the airbox need to be on or off?
  2nd
I have two manuals but they are not very clear to me on this.One says to use the adjusters on the top of the carb and the other says to use the slide stop screws,so I am not sure witch way to go.Any help would be great. Thanks Dannie
1970 CB750 JDM,1975 GL1000, 1979 GL1000, 1979 CBX, 1995 GL1500, 2000 GL1500CT Valkyrie, 2008 GL1800 Trike.
Offline keiths
Re: Carb sync question
« Reply #1 on: December 07, 2007, 06:58:26 PM »
I'm sure that someone with more experiance than me can tell you the proper way, but this worked for me. If the slide stop screws are the ones that adjust the linkage, I made that adjustment first, making sure when I turned the throttle all 4 sliders started moving at the same time. Then with the air box on, I used the top screws with the lock nuts to make the final adjustments.
Hope this helps.
Keith
Offline Johnie
« Reply #2 on: December 07, 2007, 07:14:14 PM »
Just did my 1970 CB750KO this past summer for the first time.  And with the help of this board I might add.  Keep in mind the sync is the very last thing you do.  First you have to have good plugs, valves adjusted, timing set, good points, etc.  Then you are ready to sync.  I used the Morgan Carbtune.  Get the bike warm and then set the idle at 3,000 RPM.  Then use the cable adjustment screws on the top of the carbs to sync at that RPM.  Once that is done you are ready to sync the low idle screws which are the big screws on the sides of each carb.  Do not get frustrated as it will take some time.  I did it and then had to redo the slow idle later.  Mine idles nice at 1400.  Be sure to turn a nice strong fan on the engine during this process so you do not overheat the engine.  This is all done with the air box in place.  I can even do the sync with the gas tank in place.  I just use a piece of wood to hold the back of the tank up high enough so I can get at the top adjusters.  I can also get my fingers in there for the slow idle screws, but if you have fat fingers that may be a problem for you.  Good luck with it.
« Last Edit: December 07, 2007, 07:19:52 PM by Johnie »
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
