Author Topic: Handlebar switches  (Read 1671 times)
Offline ralt12
Handlebar switches
« on: December 10, 2007, 05:33:16 AM »
Are CB400F handlebar switches the same as CB550F switches?? I'd like to put the CB 400f bars on my CB550F, and the donor has a much better set of switches.
Online Jerry Rxman Griffin aka MuthaF'er
Re: Handlebar switches
« Reply #1 on: December 10, 2007, 09:59:12 AM »
Good question that I can't answer. Best/easiest way to determine this is to cross reference this info in a site like ServiceHonda.com or BikeBandit.com for an exact match. I'm in the same situation with my 75 750F. I picked up a new right switch but a new left is unavailable. I'd like to bet that another switch is identical as far as the switch itself goes but has different length wires or perhaps different connectors that could be altered to work.
Is there anyone out there that has switches for different years/models of the same bikes that can provide some comparison info pertaining to this? This could be useful info we could add to FAQ, etc.
« Last Edit: December 10, 2007, 10:01:47 AM by RxmanGriff »
Offline hymodyne
« Reply #2 on: December 10, 2007, 10:20:45 AM »
I've got both 500 and 550K switches on my 500K1. no real differences, just some extra wires and redundancy with headlight switches being on both pods.
hym
Offline Dennis
« Reply #3 on: December 10, 2007, 09:55:27 PM »
............. I'm in the same situation with my 75 750F. I picked up a new right switch but a new left is unavailable. I'd like to bet that another switch is identical as far as the switch itself goes but has different length wires or perhaps different connectors that could be altered to work.
Is there anyone out there ................? This could be useful info we could add to FAQ, etc.
I don't know the answer to your question, but what I can tell you is that the wires on the "F" bike are longer because they connect in the electrical box on the down tubes. If I were looking for that switch, (and was willing to extend the wires) first place I would look is '75- '76 K models. I'm guessing same switch, shorter wires.
Hope this helps.
« Reply #4 on: December 10, 2007, 10:38:31 PM »
Dennis or anyone else with a 75 -76K that has a spare left control not on a bike,
-OR- for that matter, anyone that has a spare from any 750 with the same switches that knows for sure what bike it came from originally:
How about a measurement of the length of the wiring harness from the control body? We're talking turn signals, horn, and hi-lo light switch on the 75 750F. Only 1 different colored wire between the F and the 75-76K. Mine has all bullet connectors. Please indicate the wire colors and length plus the type of connectors your's has.
Offline ralt12
« Reply #5 on: December 11, 2007, 07:18:49 AM »
In looking at the David Silver site, it looks like both switches have the same part number, which kinda makes some sense; no need making a variety when the same switch will do for both. I would think that any harness differences (lengthwise) would be made up in the main harness, and not the switch portion. Of course, I don't want to confuse a good story with facts, either.
« Reply #6 on: December 11, 2007, 10:54:30 AM »
Ralt,
Check out the thread "Amazing parts list resource". It has more search options. I had mentioned Service Honda. You can do a cross reference on that site and see all the bikes a particular part is used on. Very useful.
Offline Drewery
« Reply #7 on: December 11, 2007, 04:05:20 PM »
You could also check the wiring schematics of both bikes. That should give you and indication if can swap switches or not.
72' CB500K1
69' Triumph GT6 plus
Offline Dennis
« Reply #8 on: December 11, 2007, 05:41:58 PM »
My 750 is also a '75 F, so I can see exactly what you can on your bike. I don't have any spare switches.  I did not bother to check the wiring diagrams but I am a little bit surprised that there is a different wire on the '75-'76 K models. Sorry that I couldn't have been more help.
