Author Topic: Cb400F - Carb leak after bike knocked over  (Read 5342 times)
Offline Prospect
« on: December 10, 2007, 08:48:04 PM »
Hello
Great site.  My CB400F was recently knocked over by an SUV in a secure parking lot.  There was some damage but it can all be repaired.  The bike did develop a leak from the #1 carb right after the incident.  I thought maybe the float was stuck so I took off the bottom off the carb to see but the float was moving as it should.  The bike only really leaks when sitting with the petcock in ON position.  Any ideas?
Also, what kind of spark plugs are you guys using on the 75 cb400f?  The manual says NGK D-8ESL but maybe there are better ones.
Current Bikes
1969 CB750  Sandcast #256
1971 CB750K1
1972 CB750K1
1975 CB400F
1975 GL1000 Goldwing
1954 Harley Davidson Panhead
1957 Harley Davidson Panhead
Toronto Canada
Offline heffay
Re: Cb400F - Carb leak after bike knocked over
« Reply #1 on: December 10, 2007, 08:49:39 PM »
did you verify the float was unstuck by moving it w/ your finger because that will give you a false sense of security... my guess is the float is really stuck afterall.
Offline Prospect
« Reply #2 on: December 10, 2007, 08:51:54 PM »
yes, I did verify just by moving it up and down with my finger.  How should I have checked it?
Thanks
Current Bikes
1971 CB750K1
1972 CB750K1
1975 CB400F
Toronto Canada
Offline steven400/4
  • tyre inspector
  • that nice
« Reply #3 on: December 11, 2007, 01:45:21 PM »
had the same problem with mine last weeki took the float off and took the needles out put them back and set the floats al was well and working after
steve
1978 honda 400/4 f2 my baby
Offline heffay
« Reply #4 on: December 11, 2007, 05:19:55 PM »
hi prospect... often times its not really the float that is stuck either, it is the float pin.  if the carb is still flooding there's really only one or two  options, stuck float or maybe a worn pin but, since you weren't having trouble before its probably not that.  also, when carbs get in positions like you describe often times the sediment at the bottom of the bowl gets into where the pin is supposed to seat.
my recommendation is just clean the crap out of that passageway and it should clear up.  oh, and while your at it... clean the rest of your carbs  ;)
