Author Topic: removing drum brake liner  (Read 2660 times)
Offline SEBNN
« on: December 12, 2007, 10:45:54 PM »
I am converting my rear drum brake to a disc brake setup and was wondering if anyone knows if it is possible to remove the drum brake liner.  I am looking to remove the rotating mass as I will be adding a disc and adapter plate to convert mine to something more modern.  If I cut it carefully will it fall out in pieces, is it held in with a glue, or just a press fit?
Thanks,
SEBNN
Offline rangelov
  • The Dual Disc Conversion Speedometer Driver
Re: removing drum brake liner
« Reply #1 on: December 13, 2007, 01:59:04 AM »
I believe it is cast in place.  It would be impossible to remove.
I might be wrong.  If it is pressed into place, It might fall out if the entire hub is heated in an oven.  Aluminum expands much more than iron.
http://forums.sohc4.net/index.php?topic=76835
CB750K4, Boss maroon metallic, 836cc, RC Engrg 4 into 1, Forks by Frank, air assisted front forks,  JC Whitney 16" rear.
« Reply #2 on: December 13, 2007, 06:03:04 AM »
The Hub is cast arround the drum and to remove you would have to turn it out in a lathe
Offline SEBNN
« Reply #3 on: December 13, 2007, 06:45:57 AM »
Good to know before I started cutting and throwing it all out of balance.  thanks!
« Reply #4 on: December 13, 2007, 08:11:12 AM »
The OD of the drum is not smooth it is ribbed to hold it in place.. at one point while turning it will come apart in big chunks.
why bother  riuning the hub, just run a quart less gas...
Better yet just build a nice hub if you have a lathe to use.. it would be fun and not that hard to do... look better too..
Offline paulages
  • 1976 cb735
    • DOOMTOWN RIDERS P.R.M.C.
« Reply #5 on: December 13, 2007, 11:03:37 AM »
quart less gas wouldn't reduce rotating mass. 520 conversion would though.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1976 CB550 (590cc) road racer
1973 CB750K3
1972 NORTON Commando Combat
1996 KLX650 R
Offline SEBNN
« Reply #6 on: December 13, 2007, 05:15:28 PM »
520 conversion?  Why would I reduce displacement?  Or is this referring to a wheel?
Also, does the drum or the brake liner turn into big chunks?  Is the brake liner a structural member of the hub or is it just for breaking?  And yes, this would be to counteract the addition of rotating mass that a disc will add.
Thanks for the replies.
« Reply #7 on: December 13, 2007, 05:41:31 PM »
If you are worried about rotating mass and have access to a lathe, build a hub.. be way lighter.
While at it, thin the disc and drill it if you are using the old 750 / 500 anchor.
The liner will come out in chuncks cuz it is a casting and not perfectly round, and not perfectly centered. By removing it you may cause the hub to flex slightly or even crack. But hey, its your wheel.
Offline SEBNN
« Reply #8 on: December 13, 2007, 05:53:41 PM »
Two years ago this would have been easy as I had access to a cnc.  I will probably end up just welding the rotor mount on it and loosing 20 lbs of my own weight.  Sure it won't be the same, but I dont have a lathe or a spare to practice on.  oh-well, better slight weight gain and better braking.  I'll be using a rotor and caliper off a sport bike built in this decade.  Just want to go with better components that match my rearsets.
« Reply #9 on: December 13, 2007, 05:59:07 PM »
You are going to weld a piece to the brake side of the hub?
You wouldnt need a CNC for a hub, it is way simpler than most realize, can be done with just a small lathe, rotary table would help (a bit easier) , but not that necessary.
Offline SEBNN
« Reply #10 on: December 13, 2007, 06:03:19 PM »
That was the original idea, there is about 0.5" of room where a disc would press in and be weldable.  Then I just need to worry about the spacing of the disc off the hub to match the caliper.  I like the hub idea, but I really don't have access to the right tools that I would feel comfortable riding on it.
Offline eurban
« Reply #11 on: December 13, 2007, 06:47:44 PM »
Paulages is referring to a 520 chain conversion which would use a lighter weight chain and sprocket setup.
Offline SEBNN
« Reply #12 on: December 13, 2007, 09:26:44 PM »
Ok, that makes a bit more sense than does going to a smaller bore and piston.  I will look at it, I am going to have to replace most basic drive train items, so changing sprocket and chain sizes won't hurt.
Offline rhinoracer
« Reply #13 on: December 13, 2007, 11:55:16 PM »
Like they said, the hub is cast over the drum which has eight or so oval shaped dowels sunken into the aluminum.
You can turn it down and then pop off the remaining dowels. You'll be removing a bit more than a pound of rotating mass. Ask me how I know that  : ;)
Baja native.
Offline SEBNN
« Reply #14 on: December 14, 2007, 06:56:18 AM »
Did it work?  Or did you have to scrap it?
Offline rhinoracer
« Reply #15 on: December 14, 2007, 09:08:14 AM »
I turned down the drum to a bit over half the width so the shoe centerline would still seat flat against the drum. Weight before and after revealed a drop of exactly 0.49 lb.
I havent ridden the bike with the mods, I'll post when I have.
Baja native.
