Author Topic: Big-Bore CB750 pistons in a CB350 Twin?  (Read 27534 times)
Offline paulages
  • 1976 cb735
    • DOOMTOWN RIDERS P.R.M.C.
Re: Big-Bore CB750 pistons in a CB350 Twin?
« Reply #50 on: December 22, 2009, 06:57:47 PM »
here is a cb350 piston (top- .25 over actually, but the other dimensions are identical to a STD piston... the one i have just has a big hole in the crown), next to a yosh 811 piston (bottom).
measuring from the bottom of the pin, the distance to the 811 crown is almost the same as the distance to the bottom of the cb350 crown, meaning you'd literally take the entire crown out trying to get down to the dimensions of the yosh piston. there is definitely not enough meat in this one to have 10.5/1 CR. like i said, maybe there was a particular year with thicker crowns?
paul
SOHC4 member #1050
1974 CB550 (735cc)
1976 CB550 (590cc) road racer
1973 CB750K3
1972 NORTON Commando Combat
1996 KLX650 R
Offline Leino
  • Not much of an
  • in drag racing since 2005
« Reply #51 on: April 22, 2020, 10:55:15 PM »
I just put together a 350 for a friend with GPz 750 Wiseco pistons, 69mm. Worked out fine.
Offline low-side
« Reply #52 on: April 23, 2020, 07:40:35 AM »
There's a seller on eBay offering 2mm over pistons for CB350 twins for something like $130.
Leino, did that require new liners?
Offline Leino
  • Not much of an
« Reply #53 on: April 23, 2020, 09:55:27 PM »
We used GPz liners. Can't remember how far you can go with stock liners but they were damaged so used what I had in stock.
